Page 4 of 5 1 2 3 4 5
#87534 03/15/02 06:59 AM
Originally posted by CJFEDERLE:
I just love my bostons pro 12.5's. There
nice and tight but crave power. Each of
mine get between 500-600 each and they
need more but if you got the money there
great.
what are you powering them with that they get 500-600? I still love my naks and am glad i decided to keep them. Now if only someone would buy my box wink
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
Sound by Crystal Mobile
Powered by a/d/s M860 AMP
My Ride
#87535 03/15/02 09:34 AM
Originally posted by FordTruckBoy:
Nice wireing job above......zzzzt! :rolleyes:
Yeah thanks noob, like I said it's just sitting in the trunk, the Contour goes bye bye soon and I took everything out. I just put it back temporarily so you guys could see how much space a 3 cubic foot box uses up :rolleyes: .
#87536 03/15/02 10:12 AM
Just an idea.. you could be like me, and go for JL 18w6's. Originally i was going for 6 10's because it has more surface area than 3 12's, but uses the same amount of enclosure space. But then i realized the 18's.. they very small box sizes at 1.75cuft. That's the maximum recommended enclosure size. I have 2 of those in my car in a box that is a little less than 4 cu. ft. If u look around, you could find one for sale. Just my 2 cents.
Give me more beer and CEG before i get depressed!
AIM/AOL: DBZ Jr
#87537 03/15/02 03:15 PM
Kirill Offline OP
There are quite a few people who have mounted a 8" sub under the deck. There is also an installation of an enclosure under there as well. So, it can definitely be done.
What's pros\cons of mouning 8" under rear shelf against something huge in a trunk ?
I thinkg with 8" in a opening you should get more detailed bass.
Regards,
Kirill
98.5 Contour SE Silver Frost (powered by Duratec 2.5L)
Nakamichi CD-45Z -> Phoenix Gold XS4300 -> Infinity Kappa 693.3i
\_ Blaupunkt ODx694
#87538 03/15/02 04:27 PM
APT Offline
I thinking with 8" in a opening you should get more detailed bass.
Pros:
Takes up almost no usable trunk space
Cons:
Doesn't have the low frequency output, say below 30Hz
Less efficient - need more power for free air than sealed.
#87539 03/15/02 04:33 PM
Actually, it should be more effecient. It takes less power to use up the full excursion of the woofer.
Also, it shoudl offer excellent transient response as the Q will be dependent on the Qtc of the woofer which is typically .7 or lower. The lower the Q the better the transient response.
The 8" just doesn't have the capability to move enough air to really push any serious SPL.
#87540 03/15/02 04:45 PM
I'm running a Mcinrish MC4000M.
It's six channels 100x4 and 300x2. laugh
I absoutley love this amp.
'98 E0 T-RED CONTOUR SVT
#558/6535
Got Tunes:
Sony CDXC-90, CDXT-65, XDP210EQ
MCINTOSH MC4000M
BOSTON PRO 6.5 COMPONENTS
BOSTON PRO 12.5 LF
POLK DB4500
STINGER 1FARAD CAP
RED NEON INSIDE AND UNDER
THROTLE HANG FIX
RESONATOR REMOVED
#87541 03/15/02 04:47 PM
I realyl type bad the amp is a mcintosh not
whaterve I put eek :rolleyes:
sorry
#558/6535
Got Tunes:
MCINTOSH MC4000M
BOSTON PRO 12.5 LF
POLK DB4500
STINGER 1FARAD CAP
THROTLE HANG FIX
RESONATOR REMOVED
#87542 03/15/02 05:00 PM
Nice amp!
#87543 03/15/02 05:13 PM
"bling bling" Did you pay the $4000 list? Dimensions: 2.9"H x 34"W x 12"D That's a perfect fit for an amp wall!!!
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
My Ride
Moderated by  dnewma04_dup1
