#874514 02/17/04 01:51 AM
i just got my 2nd amp , but my HU only has one set of preouts, is there any problem w/ using splitters?
98 Silver V6 SE Sport K&N w/ heat sheild, Elky mesh, fog-light mod, knauberized
#874515 02/17/04 04:03 AM
loss of fading capability....
1999 SE White AVH-P6500DVD Infinity Reference 6500CS Pioneer 5x7s Punch 360a2 Punch 500a2 Adire Tempest in a custom sealed 3.4cuft box Modded Xbox Still need Midnight Cloth Headrests... and if somebody has fold down rear seats....
#874516 02/17/04 04:45 AM
none whatsoever!
#874517 02/17/04 05:39 AM
there will be a loss in signal going to the amps
Joel Falkenberg
#874518 02/17/04 03:21 PM
Yes there will be a slight loss in signal if you split it, but you won't notice it without special test equipment.
#874519 02/17/04 03:24 PM
The loss is not even worth mentioning. It is a low level signal, it certainly will not be audible in a car.
Previous Owner of 00 SVT Contour #1077/2150 95 Contour SE '01 3L
#874520 02/17/04 05:34 PM
I doubt it would make a big difference to split it. Obviously there will be a signal loss because you are running two amps in series (off the same input signal) which results in a voltage drop across the two loads (amps) but the whole point of a car amp is to increase the gain so you should be good.
98' Contour SVT #607 of 6535 05' Mazda 6s Audio/Visual enthusiast because it's one of the many things I went through 4 years of hell for
Moderated by  dnewma04_dup1
