Posts: 3,732 |
i think jb weld could do it, we use it in our 3L hybrids  personally id take it to a welder in your area, its a better solution
Russell
Oval Port 3L Nearly Done
Posts: 233 |
Hmmm... So cracked tranny case CAN be welded or even JBWelded? That increases my options somewhat... (I have a cracked tranny case too).
Just a plain jane '96 LX V-6 here...
Posts: 1,176 |
I don't know about welded. But I did some research and the JB Weld product seems too good to be true. It states in has been used in cylinder heads! Impervious to oil, gasoline, water, etc. and can withstand vibration, pressure, etc. I am going this route and see how it works. This product has been around for quite some time from what I understand......
Posts: 1,176 |
First item checked is Drive Carrier and differential assembly. No chips, nicks, etc. All is fine.
Next item checked is the low one-way clutch assembly, It was taken apart and cleaned, inspected and all is well. Check was made of proper rotation within race to be sure it was reassembled correctly, etc.
Forward One Way Clutch assembly was taken aprt and inspected. No nicks, chipped teeth, etc. Reassembled and checked for proper rotation within race.
Driven needle bearing in case was replaced with threaded rod and puller. No problems here.
Lube tube was removed from seal in case. Seal in case was removed and replaced. Lube tube was reassembled. Apparently this lube tube is a pressure fit into this seal. The valve body provides oil to this valley which the lube tube then drips onto the driven needle bearing in case - where axle goes through. It is critical to replace this seal to ensure that good fit is made between seal and tube.
One tool that I will have to purchase is a seal protector kit. The piston seal on the clutch piston, etc. has to be compressed for it to fit into the piston assembly - other wise it is quite easy to pinch or damage the seal. I am getting a quote from Transtar Industries that has this kit in their catalog.....I hope it is not too much!!!!!
The other tool that is perhaps needed is the clutch spring compressor. This item is over a hundred dollars and more from what I have seen. However, I went out and bought 2 6" C clamps $9.99 each. I then placed 2 flat bars on the other side of the direct housing. The base of the c-clamps resed on this bar and I just clamped down on the spring retainers until I had enough room to remove the retaining clip. Total cost $20 vs $100 and more.
On disassembling the Forward/Coast Direct Clutch Cylinder assembly, I find I need to replace the retainer and springs - there are two of them. These are not that expensive. I also have to replace the Forward Clutch piston assembly. This part is about $60. I had some grooves warn into the inner surface where the coast clutch piston fits.... The rest of this assembly has been checked and is fine.
Now out to buy some JB Weld for the cracked case.....
Posts: 1,228 |
FWIW, It does work well. However, it only works as well as the prep.
Make sure you thoroughly clean the area with a good solvent. Use a dremel and open the crack a ittle to get good penetration. Also, I would consider drilling a hole at the ends of the crack to stop the crack from propagating. Use a small screw to fill the hole after applying the JB welb. Use a flood lamp to heat the area after applying and give it more than the 24 hours needed to dry. The heat will speed up the drying but still give it plenty of time to cure. It will propably be stronger than the case around it.
Have fun..
BEFORE: '99 Contour SE Sport
Duratec ATX Spruce Green
Posts: 1,176 |
Could you recommend a good solvent? Thanks for the tips I'll certainly follow them....
Bob
Posts: 1,603 |
Originally posted by btrautman: Could you recommend a good solvent? Thanks for the tips I'll certainly follow them....
Bob
99.9% Isopropyl Alcohol is your best bet. It will remove any oil and will air dry. It will not hurt any rubber or plastic or metal.
DO NOT use 70% Rubbing Alcohol. It is NOT the same.
Good luck with the JB Weld. I would have the case scanned for any further crackage that you do not readily see before attemping and after attempting repair.
Looks like your oil pump did spike, and crack your case...
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 1,176 |
OK, I was told that for a lip seal protector kit for the CD4E the price of this kit from toolsource would be $110.00!!!!! This seal kit is made by ATEC tools in san antonio. Well I really have a hard time paying for something that I will only use once and that is made out of plastic that is $110. Someone is taking advantage of somebody and it is not me!!! So, I talked to a few people, one ole boy said that when he rebuilt transmissions for a living he used "piano wire" to seat the seals. This got me to thinking, I went out and purchased a sheet of medium gauge plastic. I cut this into a strip of 4 inches high by whatever circumference I needed for the piston. I then wrapped it around the piston and pushed the piston into the assembly.....and you know what happened it worked like a champ!!!! After it was seated, I just pulled the plastic out from the sides with no problem. I thought I'd pass this tip on to those that might want to rebuild their CD4e and come across this problem!!!!!
Posts: 1,176 |
The next picture is of the case housing that was repaired with JB Weld. First crack was ground down a bit and surrounding surface roughed up, surface was then cleaned with laquer thinner, last JB Weld was mixed and applied
Next Direct/Coast- Coast side Clutch drum is reassembled
Coast Clutch Plunger Assembly
Coast Clutch Piston
Retainer Spring - Coast Clutch
Forward One-Way Clutch and Low-Intermediate Sun Gear Assembly
This was taken apart cleaned, inspected and reassembled. It is import to pay attention to how sprag is reassembled, there is an thin and thick end cap that mounts on the sprag in a specific way according to drag clip orientation.
Low One-Way Clutch Assembly, cleaned and inspected and then reassembled and check for proper rotation that indicates if you reassembled it correctly and or working correctly.
Final Drive Carrier and Differential Assembly,
Cleaned, checked for nicks, etc. and then reassembled.
This weekend I'll include pictures on the final direct/coast drum assembly completion.
Making progress!!!
Posts: 1,176 |
Well, I assembled the coast/drive clutch/drum and performed a pressure test. It turns out I had a leaking seal. removed the pistons and found one seal was torn. Looks like my homemade plastic wrap did not quite work. I have broke down and purchased a the seal piston kit locally. I have also picked up a replacement piston from Ford, it was only around 7 dollars or so. I will retake pictures using the seal piston protectors..... Guess I'll have this up for sale when I'm through with it! The pressure test method with an air compressor is a nice way to check proper sealing BEFORE it is installed back in the car!  I plan on having everything back together this weekend.
