cool thanks for the detailed help.
one more question for you, my alarm has a 2 wire harness for the door lock. in the manual it says this:
"3 Wire Positive Switched Door Locks
In this application, the red wire provides a positive pulse during disarming (pulsed + 12 volt unlock) output.
Connect the red wire to the wire that provides a low current positive signal from the factory door unlock switch
to the factory door lock control relay.
The green wire provides a positive pulse during arming (pulsed + 12 volt lock) output. Connect the green
wire to the wire that provides"
do you think i still need the relays?
