#872026 02/14/04 02:18 AM
H
H
Alright, I go out of town and I'm gone for a month. My 2000 CSVT sat without being driven the entire time. It started fine before I left but when I went to start it today all it did was make a clicking noise. Not even turning over. What could have happened just sitting there? Tried to jump it but it didn't help. All lights work so I don't think it's the battery. Help
H
H
Its possible that there are enough amps in the battery to power simple things like lights and stuff, but not enough juice to turn the engine over. Do you have access to a multimeter?
H
H
First thing your lights will work even if your battery is dead. At least it was that was on my neijhbors Escort.
Secondly I dont know what could cause it to jsut click.
Starter?
Dead Battery (good song btw)
If the weather was sustained below freezing and the battery voltage dropped it may even have frozen. (I.E. permanently dead battery)
You can try charging it if the battery has not frozen.
I would trickle charge it at 2-6amps. Do not try to quick charge it being the voltage is so low.
9
Sounds like your battery is dead (as in done for good). That clicking sound is the teeth on the starter barely touching the teeth on the flywheel. That means it isn't getting enough current to fully engage the starter to the flywheel.
Best advice I can give is to try a jump, or get a new battery (and don't let the car sit that long, especially in the cold). Hope this helps.
Sean
'99 Silver SVT Contour (2000 miles since June, now needs new front brakes and bearings) '98 CBR900RR Again (Put away for the winter)
If you haven't done it yet, unhook the battery terminals and clean the connections with a wire brush or sandpaper. Lights and stuff like that don't draw as much current as the starter. If the batt. connections are corroded a little they will still pass enough current for lights but not enough to turn over the starter, hence the starter will just click but not spin. When you unhook the battery, always unhook the ground side (negative) first and hook it up last. That way if your wrench hits ground while hooking the positive side you don't do any unnecessary arc welding. If the batt. connections are good its probably the batt.
Doug '96 Contour ZETEC T-Red/ATX
May not be bad... My neighbor's Chevrolet minivan had that problem, I tried to jump it but it just clicked, could be the Starter Solenoid, that was what was wrong with that thing
Former owner of a 1995 Ford Contour GL w/ 2.0L ATX Proud owner of a 2005 Ford Taurus SE 3.0L V6 Vulcan --Looking for Commodore stuff (Drives, Units, Amiga, games, etc)If anyone has any of this laying around and wants it gone, lemme know --
i have had similar experiences with other cars and it too was the starter solenoid.
2006 fusion sel 1998 grand prix gtp(wife) 1993 dodge shadow es(winter beater)
Ok, this sounds like my exact problem. But when I try to turn the engine over my windshiled wiper blades do a cycle.
How hard is it to replace this starter silenoid*?
-Black '96 GL 160k -Car #30953
ok, when the wipers turn on, its generally a low battery, stare at your airbag light, that should flash 1-2... when or after trying to start.
(whoever made the design of the wipers going on when low battery needs a )
