Posts: 1,325 |
I'll be home from work around 1 - 1:30 at the latest. Not sure what time Harley and Eric will be over, but I'll be there.
97 Contour SE MTX
04 Grand Caravan SXT
Posts: 1,785 |
I think that harley is going over early. I won't be there until late 5:15ish
Just a Plain SE.
AKA Big Country
I maybe path914's B**** now, but wait until he needs his clutch done. We will see WHO is WHO's B**** then!
Posts: 28 |
I might be able to make it up tomorrow cause I don't have class, if you guys don't mind. Maybe I can finally get this 3L thing planned out.
Posts: 1,325 |
Originally posted by FightinVikin: I might be able to make it up tomorrow cause I don't have class, if you guys don't mind. Maybe I can finally get this 3L thing planned out.
Tomorow was today - we (Eric, Harley and I) got the tranny up and bolted in. BIG THANKS!!! guys - that thing is big and bulky and I can't imagine putting it up with one or even two people. I think I'll put the axles back in tonight and then leave it alone 'till tomorow.
97 Contour SE MTX
Posts: 1,325 |
Final post on this unless something goes wrong when I drive it.
Subframe went back up, tranny is filled, clutch is bled, ps is filled, steering column connected, tie rods, shocks, sway bar, ypipe and cat...
99% done other than rechecking important bolts. I do have to get a new pinch bolt for the ball joint - some of the threads were chewed up beyond reuse. Hopefully the dealer has them and it'll only be like 5 mintuess more work
97 Contour SE MTX
Posts: 2,469 |
congrats. And you sure did alot more work than me and eric. When we worked on my car. I wouldnt even get my tools out until eric showed up. So with that said when are we all going for a drive ?
Posts: 1,325 |
 I got the pinch bolt today, it's off the jacks and started right up. I still had air in the clutch and scared myself "oh [censored] the clutch won't disengage"  I bled it again and it shifts good, but there was still some drag with the clutch pressed so I think I may have a bubble or two left to get out. Thanks for your help again!!
97 Contour SE MTX
