Page 6 of 8 1 2 3 4 5 6 7 8
#870528 02/29/04 03:00 AM
ScottK Offline OP
Originally posted by dubkatz:
Originally posted by ScottK:
BTW - Eric you left your hat and shades here yesterday.
He leaves his hat and glasses everytime he comes to my house
I was going to collect up his watch and glasses and what not and sell it on E-bay
Thanks for your help guys!
For the intrested readers the tranny is off and the clutch removed.
The flywheel looked darn near perfect - no discoloration at all, no cracks (what do you expect with only 30k miles!). Almost completely perfect except for one small groove on the outer lip that was probably the edge of the disc wearing in. Will go for a very light clean up monday. The rear main seal was leaking pretty good, but there was no sign of oil on the clutch side of things. Helps explain the qt or so a month I've been using, also looks like theres a bigger leak from the oil pressure sender or cam position sensor - lots of oil behind the ac compressor.
The disc was jusst very very thin, and at some point (probably an accidental downshift to second instead of 4th) I had craked 3 of the arms holding the disc to the hub
I have the new rear main, and the flywheel will be done on Monday. Then we just need to find aanother time to get together to lift things up and start putting it together.
97 Contour SE MTX K&N 3530, UR UDP, 19# Injectors, mystery mod, FMS wires, Fordchip.com chip, SVT: TB, Flywheel, clutch, exhaust 04 Grand Caravan SXT
#870529 03/02/04 02:08 AM
ScottK Offline OP
Well, I got the flywheel machined today and have the other misc parts. I'll put the rear seal / flywheel / clutch back in probably tonight.
I'm curious if anyone would be able to swing by any time this week just to help lift the tranny up and get a few bolts in it. Everything else I can work on myself, but there's no way I'd get that tranny back up without one or preferably two extra helpers.
It's funny, when I dropped off the flywheel the guy asked what it was from. I said Contour, he raised an eyebrow and asked "4 cylinder or 6?". I replied 6, and he said "You're a brave soul." Apparently it's one of there least favorite clutches to do
#870530 03/02/04 05:20 AM
wed. im off at 12:30pm I could come by after work if you wanted.
98 csvt t-red.. sho-shop intake, b&m, fidanza, spec1 clutch, Torsen, DMD,optimized Y& TB, Brullen, rear strut bar,h&r's,17" konig traffik's. "I say what I mean and I do what i say"
#870531 03/02/04 05:41 AM
ScottK Offline OP
That'd kick ass - my wife would be very happy to not have to cart me around anymore. I could probably be done with it completely by thursday night if it works out.
I'm thinking it takes 3 to get it back up - so hopefully Eric could swing by some time too?
#870532 03/02/04 06:06 AM
I could swing buy wed after work.
Just a Plain SE. AKA Big Country I maybe path914's B**** now, but wait until he needs his clutch done. We will see WHO is WHO's B**** then!
#870533 03/02/04 06:17 AM
ScottK Offline OP
Sweet - just let me know what time is good and I'll make sure I'm here!
#870534 03/02/04 10:38 PM
The earlest, I dont realy want to drive to work. (sorento valey.) go home and then drive back to poway. But if i could hang out get lunch for an hour or two. that will work fine.
#870535 03/02/04 11:21 PM
ScottK Offline OP
I can get out of work anytime (or just take the day off to finish the whole project) - so whenever is good for Eric will work for me.
Hopefully he's not working 'till too late?
#870536 03/02/04 11:23 PM
I try to come in early so I can get off early. I would like to see you car start tomorrow.
Where did you get the rear main oil seal and flywheel bolts?
#870537 03/02/04 11:44 PM
ScottK Offline OP
Perry Ford, down the road (full price )
Paid full price for my tie rod end there too.
Moderated by  Fmr12B_dup1, path914
