Posts: 1,325 |
Originally posted by dubkatz: Originally posted by ScottK:
BTW - Eric you left your hat and shades here yesterday.
He leaves his hat and glasses everytime he comes to my house
I was going to collect up his watch and glasses and what not and sell it on E-bay
Thanks for your help guys!
For the intrested readers the tranny is off and the clutch removed.
The flywheel looked darn near perfect - no discoloration at all, no cracks (what do you expect with only 30k miles!). Almost completely perfect except for one small groove on the outer lip that was probably the edge of the disc wearing in. Will go for a very light clean up monday. The rear main seal was leaking pretty good, but there was no sign of oil on the clutch side of things. Helps explain the qt or so a month I've been using, also looks like theres a bigger leak from the oil pressure sender or cam position sensor - lots of oil behind the ac compressor.
The disc was jusst very very thin, and at some point (probably an accidental downshift to second instead of 4th) I had craked 3 of the arms holding the disc to the hub
I have the new rear main, and the flywheel will be done on Monday. Then we just need to find aanother time to get together to lift things up and start putting it together.
97 Contour SE MTX
04 Grand Caravan SXT
Posts: 1,325 |
Well, I got the flywheel machined today and have the other misc parts. I'll put the rear seal / flywheel / clutch back in probably tonight. I'm curious if anyone would be able to swing by any time this week just to help lift the tranny up and get a few bolts in it. Everything else I can work on myself, but there's no way I'd get that tranny back up without one or preferably two extra helpers. It's funny, when I dropped off the flywheel the guy asked what it was from. I said Contour, he raised an eyebrow and asked "4 cylinder or 6?". I replied 6, and he said "You're a brave soul." Apparently it's one of there least favorite clutches to do
97 Contour SE MTX
Posts: 2,469 |
wed. im off at 12:30pm I could come by after work if you wanted.
Posts: 1,325 |
Originally posted by dubkatz: wed. im off at 12:30pm I could come by after work if you wanted.
That'd kick ass - my wife would be very happy to not have to cart me around anymore. I could probably be done with it completely by thursday night if it works out.
I'm thinking it takes 3 to get it back up - so hopefully Eric could swing by some time too?
97 Contour SE MTX
Posts: 1,785 |
I could swing buy wed after work.
Just a Plain SE.
AKA Big Country
I maybe path914's B**** now, but wait until he needs his clutch done. We will see WHO is WHO's B**** then!
Posts: 1,325 |
Originally posted by myfastse: I could swing buy wed after work.
Sweet - just let me know what time is good and I'll make sure I'm here!
97 Contour SE MTX
Posts: 2,469 |
Originally posted by ScottK: Originally posted by myfastse: I could swing buy wed after work.
The earlest, I dont realy want to drive to work. (sorento valey.) go home and then drive back to poway. But if i could hang out get lunch for an hour or two. that will work fine.
Posts: 1,325 |
I can get out of work anytime (or just take the day off to finish the whole project) - so whenever is good for Eric will work for me.
Hopefully he's not working 'till too late?
97 Contour SE MTX
Posts: 1,785 |
I try to come in early so I can get off early. I would like to see you car start tomorrow.
Where did you get the rear main oil seal and flywheel bolts?
Just a Plain SE.
AKA Big Country
Posts: 1,325 |
Perry Ford, down the road (full price  ) Paid full price for my tie rod end there too.
97 Contour SE MTX
