Posts: 26 |
Does anyone know the shift points on a 95 contour 4 cyl MTX. I need to know by the speed because i do not have a tach on my tour.
Posts: 2,166 |
Did you check the manual?
- Zack
WANTED: T-Red HEATED Side Mirrors
FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps
2000 T-Red SVT
1995 LX V6 MTX (RIP)
Posts: 21,653 |
Shift before it sounds like it's gonna explode. j/k Acceleration: 14;25;33;48 normal driving 12;20;29;40 Though you can probably shift higher if you really gotta get somewhere. And for about $25 you can get an instrument cluster from a junkyard w/ tach.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 9,602 |
A car with a manual tranny and NO tach!!!  How absurd...  Your best bet is to measure your tire diameter and then figure out what the MPH is in every gear based on tranny gear and final gear. Very simple really!
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 2,725 |
Would putting in a tachometer cluster into a non-tach work, I dont have a tach either but want one.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by HITMANinMI: Would putting in a tachometer cluster into a non-tach work, I dont have a tach either but want one.
Yes it will work.....just try to get the same year, same engine and you will be fine.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 2,166 |
Originally posted by LoCoZ: Originally posted by HITMANinMI: Would putting in a tachometer cluster into a non-tach work, I dont have a tach either but want one.
Also, I believe only the Mystiques have I4's with a Tach, so if you're searching, take a look at them.
- Zack
- Zack
2000 T-Red SVT
Posts: 2,725 |
I'm not trying to second you guess you here or anything but I got a few questions.
If I put that in with all the lights, brake, oil, CEL, seat belt, battery, and the O/D etc., all still work or will I have to move bulbs around?
Also my other question is how will it work since it wasnt designed with a tach in it. The connectors back there and just fit into both cluster or something?
thanks
Posts: 21,653 |
Actually some zetec Contours had tachs as well, even ones with autos... It's all plug and play.. Just buy the cluster for about $25 at local junkyard or www.car-parts.com (specify your exact model) and remove old cluster (some screws can be hard to get to, but not a big deal) on 96+ there are two connectors back there, connect them and you're good to go. For 95s, it may be different.
98.5 SVT
Posts: 5,600 |
or just buy one of those ricey moster tachs and bolt it to the top of the dash. they go to 10,000 rpm, which will leave you some room incase you do some not yet invented mods to the contour.
Black 1998.5 CSVT
