#868309 02/10/04 06:44 PM
Also here recently my coolant light the one w/ the fan on it has been comin on. It comes on when it's normally around 20-30 degrees outside. My coolant reservoir is filled to the max line and the car runs fine, the heat comes on and works fine and the light will go off after the car warms up (normally about 5 min.) Should I flush the radiator or what?
#868310 02/10/04 06:58 PM
Z
Z
Hey Patrick,
I suggest searching around here prior to posting as this has been discussed many times.
It is well known on this site that the Coolant Level Sensor is VERY sensitive. Fill your coolant above the Max line, and the light will go out.
Good Luck!
- Zack WANTED: T-Red HEATED Side Mirrors FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps 2000 T-Red SVT 1995 LX V6 MTX (RIP)
#868311 02/10/04 07:00 PM
Thanks, sorry bout that it's been a while since i've used the site. I was in kinda a hurry today too but thanks though.
#868312 02/10/04 08:11 PM
N
N
Fill it 1 inch above the max line and you'll be fine.
#868313 02/10/04 09:04 PM
Just happened to notice this post as my car was doing this also but I didnt really care, but thank you for the info on the fix. Now I can get rid of that light for good.
Black 99 Contour SE Sport V6 Orion SX275 (the old black ones) 2 12" Kenwoods 350's
