Pipe Offline OP
Hello Folks !
I´m new here and just wanted to make a short introduction:
Real name´s Heiko, I´m a German and work as a Volvo aftersales manager in Brazil.
A very close costumer of our company brought us a 1995 Contour SE to the workshop with the underhood wiring harness cracking and deteriorating. After some research in the Internet I came across Ford´s recall ONP 99M03 which previews the replacement of the harness.
That´s why I come to you in order to figure which procedure I should follow to obtain the wiring harness(es) from Ford. To whom I should talk and which data is required ?
Thanks in advance for your answers !
Pipe
Res Severa Verum Gaudium
Call ford motor company and see if you can get that recall done. go to http://www.ford.com and click on contact us. and welcome to ceg!
1999 Ford Contour SE Zetec with 137k miles. AIM Name: ContourAlf Yahoo IM: Contour_Freak
My suggestion would be to call Bill Jenkins at Signature Lincoln/Mercury in the USA. The number is +1-702-457-0321
I suspect he may know the answer, or know who does.
Z
Z
Be sure to mention you are a part of CEG (Contour Enthusiast Group). Bill helps us out all of the time and would definately be able to answer your questions.
- Zack WANTED: T-Red HEATED Side Mirrors FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps 2000 T-Red SVT 1995 LX V6 MTX (RIP)
Pipe Offline OP
Thanks a lot for your swift answers !
Inquiry is on its way.
Pipe
When i took mine to the dealership the other day they replaced a recall it was an A/C fan belt.. apparently it was a serious recall cause it had mentioned somethin about the harness sparking and igniting the engine. Never heard anything about it till then, kinda odd.
