#867735 02/10/04 03:17 AM
i'm going to build an engine while I drive my csvt, and put it in in the summer. Here's my question..Do I...
a). swap in whole 3L, block and all?
b). use 2.5 block w/3L parts?
c). rebuild new 2.5 from ground up?
I'm going to be putting in new everything except for the block. New crank, cams, pistons, heads, but I don't know which one would be the most reliable and most efficient. I'm not new to building engines, but I don't have any experience w/the duratec family until this point. If anyone can help, even with suggestions for the crank, cams, pistons, etc... Let me know. thanks
jeremy
98 CSVT silver frost mods: 893 fogs, 2 12" free airs, alpine HU future mods: LED taillights, In door 8's...who knows?
#867736 02/10/04 04:34 AM
If its 01 then yes
Uhh?
Why is yours bad?
For a 'experienced' engine builder it doesn't sound like you understand the benefits of the larger bore on the 3L which is a guranteed 30/30 hp/tq advantage. Why would you want the 2.5 if your building a N/A engine? FYI The 2.5 crank, and rods are the same as a 3L.
#867737 02/10/04 05:26 AM
kinger, thanks for the info. I meant 3L block w/2.5 heads.. Would that be better than a 3L block w/3L heads?
98 SVT Mostly stock..focus shift tower, fog light mod... kickin free-air stereo
#867738 02/10/04 06:11 AM
I'd recommend doing a full swap with an 01+ 3L myself.
#867739 02/11/04 01:20 AM
Y
Y
Would this prove to have more power than a Hybrid?
#867740 02/11/04 01:54 AM
W
W
Not really, just cheaper and maybe easier to get the same or almost the same power as the average 'decent' hybrids.
There is one thing to say for a basic hybrid. With very little money, no valve changing, only the basics; you can do it extremely cheap and it will outperform even a well modded 2.5L. However, the straight 3L swap with SVT cams will net you more power than the really cheap hybrid.
#867741 02/11/04 05:13 PM
What timing chain set-up are you using, the older larger 10mm? I would assume so with the SVT cams. Is it a PITA to modify the lower end of the 01 engine to use the larger older sprokets?
#867742 02/11/04 08:49 PM
Redneck Troll
Redneck Troll
The rule is, if you're using skinny chains, use skinny sprockets, adjusters, and slides. Thick chains use thick adjusters, slides, and sprockets. The older sprockets slide right on the end of the crank just as the thin ones do. No mods needed.
#867743 02/11/04 09:52 PM
Both sprockets slide right on the end of the crank just as the thin ones do. No mods needed.
Exactly.
Whatever you do make sure you do not interchange any of the parts.
Normally the older sprockets are 1 piece while the new sprockets are 2 piece.
