#86742 02/22/02 09:24 PM
How did you fit 6x9s in your doors? I have some Pioneer 6x9s I had in my Camaro that I wanted to put in my car since I kinda blew up the rear speakers. And I also have a set of 6x9 Pioneers I had in my Sundance I want to put up front. What all was involved in cramming them into your doors?
Remy
T-Red 2000 SE Zetec ATX
Gutted Air Box
Removed Door Ding Guards
Added Side Markers
#86743 02/22/02 10:12 PM
I have 6X9's and all I had to do was drill new wholes in the door and screwed them in.
Chris Bertrand , !!16 years young!!
1995 Ford Contour Gl 2.5 V6 MTX
My DIMS (DO IT MYSELF) Achievements:
Performance Mods: None
Audio Mods:Jvc head unit, 6x9's in all doors , Sony XM-752EQX amp, 2 Sony Xplod LS-1235 12" Subs
Video Mods:Blaupunkt DVD-ME1, 2 5" monitors in sunvisors
Aesthetic Mods:Neons, Streetglow El Shift Knob
Commando LCD Pager Alarm
Many Mods To Come.......
#86744 02/22/02 10:16 PM
Kai Offline
For the fronts, all you have to do is drill new holes. (Unless they are really deep, then you'll need a spacer.)
For the rears, I had to grind away some of the door where the bracing on the speaker was. Some people instead cut/ground the door handle brace, but i wanted to leave that.
Overall, not a bad job. I have pics of the door panels off if you'd like to see them.
Kendall
'97 GL Zetec ATX
" Nippy "
#86745 02/23/02 06:57 AM
Yeah can I see the pics? Do you have any pics showing what part you are talking about that I have to grind/cut?
Remy
Gutted Air Box
Added Side Markers
#86746 02/23/02 04:26 PM
It is the metal bracket where the handle screws into. It sits tright on the edge of the hole.
#86747 02/24/02 03:42 AM
Kai Offline
I'll get the pics up ASAP. I just gotta find my disk! mad Where'd it go?!!
Kendall
'97 GL Zetec ATX
" Nippy "
#86748 02/26/02 04:05 AM
Kai Offline
Ok, finally found em.
[img]http://kai_se.tripod.com/fronts.txt[/img]
[img]http://kai_se.tripod.com/rears_marked.txt[/img]
I actually ground out about where I marked in blue, so the speaker bracing could slid in. That will vary depending on the speaker, of course. Most people, however, grind that handle piece away, as marked in green. smile
Kendall
'97 GL Zetec ATX
" Nippy "
#86749 02/26/02 08:47 PM
Thanks man! I'll try that this weekend!
Remy
Gutted Air Box
Added Side Markers
Moderated by  dnewma04_dup1
