Posts: 1,224 |
Are you changing to solid lifters? Or will they work fine with hydro lifters?
Just wondering because Cat cams has different cams for solid vs hydro.
Later, Ben
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by ZetecNinja: Aren't Stage 1 cams like "high torque" cams, I thought there wasn't much gain from them?
Stage 2 are high rev.....above and around 7000 rpms.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 8,143 |
well you should be okay then...7200 RPM chipped right
Posts: 2,483 |
Stage 1 cams for low to mid end TQ, not changing anything else. I can't use Stage 2 (safely) with nitrous, not without alot of extra tuning.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by ZetecNinja: well you should be okay then...7200 RPM chipped right
7300 RPM redline/fuel cutoff.....6750 RPM shift points at 90%+ thottle.
Hector
257HP/259TQ
160HP/141TQ
Posts: 8,143 |
Read this thread over on focal jet...wonder if anyone here (SleeperZ) would have the same problems. Read
Posts: 2,483 |
Yet another reason to only go to Stage 1 cams. Stage 2 is not worth the trouble.
Posts: 8,143 |
Originally posted by SleeperZ: Yet another reason to only go to Stage 1 cams. Stage 2 is not worth the trouble.
so you don't think u'd encounter similar problems with the stage 1 cams?
Posts: 2,483 |
The problem depends on the manufacturer and stage of the cams. Stage 1 is least likely to have a problem, and as far as I know, no Cougor or Focus owners have had a problem with the cams that I have. I can't say with 100% confidence, but if that's the only problem, a little milling will fix it.
Posts: 130 |
Ok, i got a 98 zetec VCT(N) i think anyway...my spark plug cover says VCT and im pretty sure its not been put on there...is there any other way to tell if for sure it is VCT? ok...heres my real question...if it is VCT what cams will work in my car?
