#86276 02/13/02 03:15 AM
V
vinny Offline OP
V
I ordered some new speakers and they should be delivered tommorow. I was wondering, are the door panels on the svt's a pain in the ass to remove? I used to have a nissan maxima that I did most of the stereo install on myself, and the door panels were very easy to remove. I just no I wont have too much time on my hands, but if it's a fairly easy removal I'll have at it. Thx
vinny "2000 T-RED SVT"
Mods:
kkm
sho shop off road y-pipe
Audio:
Alpine CDM 7874
Audio Control 4.1 EQ/Line driver
Mb quart rsb 215 comp.
Mb quart rsc 216 comp.
blueprint 1001 sub
2 Phoenix Gold qx2180 amps
#86277 02/13/02 03:21 AM
A couple screws on the front edge, a couple on the bottom, then a couple hidden in the center strip in the door grab and then two under plastic snap covers one of which is in the back of the door release area. Not too hard to take off, at least theres no damn plastic push tabs!
Rick
The first Blown 3 Liter!
"Drive it till the wheels fall off" -my personal motto!!!!
98.5 T-Red SVT #6180
Many Mods
Buckshot77@aol.com
Owner of 00 #1611 Silver
Totalled on 10/7/01
SVT Parts for Sale
#86278 02/13/02 03:23 AM
V
vinny Offline OP
V
sweet, no push tabs. I had those on my mazda mx 6, and I broke just about all of them. thx
Mods:
kkm
Audio:
Alpine CDM 7874
blueprint 1001 sub
#86279 02/13/02 07:37 PM
check this one - http://msnhomepages.talkcity.com:/ProtectionFault/modemjunki/C-doors/front_door.html
Regards,
Kirill
98.5 Contour SE Silver Frost (powered by Duratec 2.5L)
Nakamichi CD-45Z -> Phoenix Gold XS4300 -> Infinity Kappa 693.3i
\_ Blaupunkt ODx694
#86280 02/13/02 07:50 PM
I replaced both my speakers yesterday, so let me give some advice.
The sail panel has a plug with a screw behind it. Both of mine were near impossible to remove. I used double sided tape, and even superglued a wooden peg to it to pull it out. One came off in this way, and the other didn't. Finally I carefully drilled through it and now need a new plug. So be warned.
Also, I don't have power door locks or windows (so your's may be different), but the plastic cup that sits behind the door pull on a '95 is very thin and easy to break.
Another thing to watch out for is the bulb on the lower corner lights. The wire can be short, so if you pull off the door panel you'll break the wires to the bulb housing. So remove the door screws and then pry that corner off and get your fingers behind the bulb and twist and pull it out.
Moderated by  dnewma04_dup1
