Posts: 1,246 |
It's Fake! Mikey Boy's explaination is true. Compare the two pictures and pay particular attention to the driveway of the house furthest left. The driveway does not line up.
Posts: 239 |
I am still going to have to say that its real. Took the pic by 4 architects and 2 contractors yesterday while I was up at studio and they all agreed that while poorly designed, that stuff happens. First, about the grade height from the street. Yes there is code but it often varies and can be quite high for area that have excessive rainfall. About the fill undeneath the far driveway. Everyone I showed it too said it just looked like dead grass. About the bottom width. Code in most stated say that the minimum base width is 8 feet, that appears wider than 8 feet. About the drain 2+ feet above the ground. Simply poor coordination between subcontractors. Finally about the "lack" of an exit. All concrete on a project is not poured at the exact same moment. They probably underestimated the need and had to put it off a day or two. Sorry, but it is real.
Totalled 99 SE Sport
03 VW Jetta GLS 1.8T
APR DPP 93 Octane chip
Posts: 239 |
Just noticed, there is an exit for it in the first pic to match the second (highlighted). Its just covered up by a pile of dirt in the perspective. Whould someone go to the time to chop in a covered up exit too?
Posts: 970 |
just look at the furthest driveway in the 1st pic. Look at the dirt pile obscuring it. Look at the same dirt pile in the second pic.
a. it is the same
b. even if it wasn't, it would cover the driveway more in the second pic, not less. (unless it is a magical dirt pile or has light bending properties).
That is the simplest and strongest evidence...
Still not convinced?
Look at the dirt pile on the far side of the furthest driveway. Look at the 3 trees behind that pile.
a. same perspective in both pics (it's exactly the same FFS) even though the camera is at different locations as shown by the sidewalk...
98 GL sport (V6 MTX)
The Durable Duratec? - (DMD, Metal impeller WaterPump, Synth & Stinky in the tranny)
Posts: 93 |
If you compare both pictures it is obvious that they are real. If they are such "bad photoshops" then someone should be able to show us an artifact. Just show me one pixel repeat, one mask edge, one grain variation, one blurred edge, ONE ANTHING!.
doug
sturgis, michigan
1998 SVT Black
Posts: 328 |
Originally posted by 24vHO: If you compare both pictures it is obvious that they are real. If they are such "bad photoshops" then someone should be able to show us an artifact. Just show me one pixel repeat, one mask edge, one grain variation, one blurred edge, ONE ANTHING!.
On top of being a blind fool you are a smart azz to boot...
THE DRIVEWAYS DONT MATCH UP IN THE FIRST PICTURE LIKE THEY DO IN THE SECOND PICTURE
DUHHHHHHHHHHHHHHHHHHHHHHHHHHHH!
1999 CSVT-Black 15.8@89mph
Driver for hire. PM me.
Posts: 1,384 |
only CEG would take it to this level...guys we're a bunch of nerds...lol
99 Black Contour SE Sport
Posts: 93 |
Originally posted by ancientsanskrit: only CEG would take it to this level...guys we're a bunch of nerds...lol
Isn't that the truth
doug
sturgis, michigan
1998 SVT Black
