Pete D Offline OP
I finally got the wiring harness for the CD-40Z and 2 sets of Bullet connectors from Radio Shack. Well I get all the junk laid out tonight and go to start connecting things but I am having the hardest time crimping the stupid radio shack connectors, all they do is deform when I bend them and the wire still slips out, it says it's for 14-16 gaugue. I am thinking of just saying hell with it, cutting off the other connectors and splicing the wires, should I use regular electrical tape? I've done that before on other HU's but not sure if there is something else I should go for? confused
Thnx
-Pete
Every time I come online I wonder if the forums will be up
I am a firm believer of solder/electrical tape for my connections. Do that to the wire harness and you should be good.
David Litsky
AIM: DaveL225
My Car
Soldering and heat shrink would be a great solution if you don't like using the crimp connections. I personally wouldn't use electrical tape. Electrical tape becomes a problem with heat. It looses its adhesion ability with time; your wires won't be insulated resulting in a short.
1998 Contour SVT
H&R, Koni's, 17" Team Dynamics DTM
Upgraded Stereo System
My 98\' SVT
Pete D Offline OP
Ok, well I don't have a soldering iron here and the one at home needs a new tip so I would like to stay away from that, how do you use heat shrink tubing (yes I know that is a stupid question)
-Pete
just buy some tip cleaner. or a new tip (they're only $1). Any way, to heat shrink, all you need is enough tubing to cover the joint, slide it on before you connect the wires, of course. Then, use a blow drier (on the hottest setting) and apply heat to the tube untill it shrinks (should take about 5-10 seconds). Easy enough eh? hence the name heat shrink tubing, its NOT intended to hold wries together, its only meant to be a neater substitute to electrical tape..
Silver 1998 Mystique LS (v6)...ATX frown
Removed Emblems, limo tint, painted calipers.
Premier P630 HU with 4 Pioneer TS-A6895 Speakers with 10' Sony sub (yeah i know, i'm cheap)
Commando 501-S Alarm
Originally posted by Pete D:
Ok, well I don't have a soldering iron here and the one at home needs a new tip so I would like to stay away from that, how do you use heat shrink tubing (yes I know that is a stupid question)Pete
New tips are cheap. go pic some up it's the best way to go.Slide the heatshrink on the wire before soldering. solder, slide shrink over conn. and heat
98.5 SVT#6092 of 6535 B/MNB
Born on date 5/22/98
Y2K Suzuki GSXR 750 Y/B with 140.6HP
I had a hard time using the Butt connectors (is that the same as the "bullet" connectors from radio shack?) Anyway, I finally borrowed a crimping tool and it worked great. Very tight connections. I don't know what it would cost to buy one, but it was much easier than soldering in the long run, if you have the right size connector for the gauge of wire you are using.
Moderated by  dnewma04_dup1
