#861670 02/03/04 01:34 PM
MelC Offline OP
I am new to this site!
I am the proud owner of a white 1999 Contour SE Sport "The Biscuit"
I have made the decision to start working on the biscuit myself and I would like to get some advice on level of difficulty of the things I am attempting. It looks pretty tight under the hood, but I am armed with a repair manual and a shop full of tools. I know that I need to change the 02 sensor. I have had to replace every year and the CEL has come on again. How hard is this one for a DIY? Also, I am planning to change the spark plugs and wires. The biscuit has 103,000 miles on it so I am wondering if you guys could tell me if there is anything in particular I should really pay attention to. I changed my brakes couple of months ago, I am planning to get a tranny service soon, and of course the oil change is up to date.
Am I crazy?
Thanks!
#861671 02/03/04 01:53 PM
MelC,
Congratulations on the purcahse and welcome to CEG. You are correct in saying that it is tight under the hood. You took the first steps though to sucessful DIY repair by getting a repair manual, having tools, and finding this forum. I suggest just opening the hood and looking around for a while, just to get used to where everything is first. This way when you are viewing posts on this site, you can visualize what is being said. Also check out the following link off the main page. It has lots of common issues and How To's.
How To Section
You mentioned your O2 sensor. This car has 4 of them. The trickiest one to replace to Bank 1 Upstream. Read over the How To to make sure you have all the necessary tools and info first. You will soon learn that in order to do repairs on this car, you will need lots of extenstions and swivels and you will need to take a lot apart to fix minor things.
Upstream Bank 1 O2
Anyway, I am sure others with chime in to help you out too. I just wanted to say Welcome once again and best of luck with the car.
99 SE V6 Silver Frost 201,592 Miles (Still Running Well)
#861672 02/03/04 02:06 PM
WOW!!!!
Now thats how you greet someone, I bet Todras is fumin'!!!
www.ChicagoCEG.com 2006 White Grand Prix
#861673 02/03/04 02:07 PM
Oh yeah, and welcome to the site. The worlds second most popular disfunctional family
#861674 02/03/04 02:12 PM
You're not crazy. Every day, in every way, you're getting better & better. You should verify that you have a V-6 under the hood so we are sure of what you're asking us.
I would have the codes read & perform a search for them here if I were in your shoes. Annual CEL battles are not neccisarily the norm. You may have seen posts that tell you they can be read for FREE at Auto Zone. A little research can (and likely WILL) save you tons of time & money. Really, do it. CEG has an enormous database of info that you can easily sift through to get info you need.
Now, assuming that you have a V-6:
You have 103k miles so you should seriously consider a TB (Throttle Body) cleaning.
You should also visit the FAQ section of the main site to see if you can find a proceedure for Upper & Lower Intake Manifold (UIM/LIM) cleaning.
After those two, your car will run almost like new.
You're a noob, so you may not know that the best plug for the V-6 is the Autolite APP764 double platinum. Anything else is a waste of time & money regardless of cost, period.
Plug wires, you have choices (in order of preference):
1 Magnecore
2 Stock
3 Autolite Pro-fit series
If you want pretty colors, you can get Ford Racing Wires. They are about 1/2 the cost of the above choices, but you can expect to replace them more frequently, & they may not fit properly in the plastic looms that guide the wires back to your coil pack.
When replacing plug wires, pay particualar attention to where you plug them in and be sure the connections are nice & snug. A mis-routed wire can be a tricky thing to track down & will make you quite unhappy for a week or two. Mis-fires suck, trust me. They can also damage your engine if left un-treated.
This should be enough to get you started. All of the above are do-it-yourself jobs & not difficult. EVERY LAST ONE is a great maintenance item that will help bring your car back to life in a BIG WAY when they have all been completed with your tune-up.
#861675 02/03/04 03:08 PM
MelC Offline OP
I thought all sport models are v-6s...shows how much I don't know huh?
#861676 02/03/04 03:41 PM
Originally posted by radioactive:
Upstream Bank 1 O2
That says you can't use an O2 sensor socket to replace the bank 1 sensor, but had no problem using an O2 sensor socket on my '95 V6 to replace that sensor.
Do the '96 and newer models have less room there?
#861677 02/03/04 04:27 PM
Starting in 1999, you could get either engine in the SE. Many here theorize that SE stands for Surplus Equipment.
