Page 2 of 2 1 2
#859298 02/01/04 08:04 PM
It does work much better when the herb is dry, as I found out last night. I have yet to taste it, but it should be good. What other herbs or spices do you add to your salsa? I generally stick with just cilantro, but it might be interesting to try out some other stuff to see what happens.
Andrew
Andrew 1992 Toyota Celica GT Formerly Mines SVT
#859299 02/03/04 11:30 AM
Rinse off any dirt under cool water.
After washing the cilantro, hold it by the stems (best if the bunch is still tied together) and give it a good shake to remove excess water.... maybe even pat it on paper towels.
Then, still holding it by the stems, roll it on your cutting board to gently fold/press the leaves together, tucking the ends in... when the leaves are in a more manageable compact group, they are very easy to cut. Just cross-cut until you reach the stems, or stop earlier if you want less stems.
'95 'stiqueLS 2.5L ATX S&B / CTA intake KEM Mag-Plus wires 1/4" TH fix Homemade heat shield Xenon bulbs Fog light rewire ATX cooler Flowmaster 942042 Blacked-out pseudo-chrome
#859300 02/03/04 02:57 PM
DDV Offline
Since the most flavor is in the leaves, wash and dry as mentioned before, but then pluck the leaves from the stems. Dice only the leaves and discard the stems. Don't dice them too much, either.
Good luck,
DDV
#859301 02/06/04 01:45 AM
Z
Z
Another small factoid... the seeds of the same plant is coriander.
Place to get great stuff... Great Spices.
Brad "Diva": 2004 Mazda 6s 5-door, Volcanic Red Rex: 1988 Mazda RX-7 Vert, Harbor Blue.
Page 2 of 2 1 2
