Not if it's Sheehy Ford in Springfield, VA
I just showed them the cracked wiring on my fan harness and they agreed to do the 99M03 service. As a result, I had them fix an oil leak (from the crankshaft oil seal...also had them install a DMD I got from Bill Jenkins at the same time) and a new serpentine belt, and I had them replace the motor mounts, do an oil change, an alignment, and the VA safety inspection.
Battlefield Ford in Manassas, on the other hand...they suck. Stay away.
(In the unlikely event that anyone from warranty-battle field Ford is reading this, this is what happens when you refuse to perform warranty work--the customer goes to another dealer, gets the warranty work done there, and has that other dealer do some additional work while the car is there--which you, Battlefield Ford, would have gotten to do except that you suck and treat customers like dirt. In other words, you lost out on several hundred dollars of parts and labor, and when I buy a new Ford Futura, who do you think I'm gonna buy it from??)
