Posts: 2,517 |
Yo, I FINALLY got to sending you the money. Sorry it took so long!!
Posts: 4,294 |
Originally posted by chknhwk: Yo, I FINALLY got to sending you the money. Sorry it took so long!!
PM me with what you are ordering, size. I know you are getting blue and 50 of them but thats it.
95 SES Sold
99 SE Sport Sold
99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
Posts: 4,294 |
Just a few days yet you guys. Come on this is a great opportunity to get in on this. I will have install guides ready by the time you guys get them in the mail.
95 SES Sold
99 SE Sport Sold
Posts: 9,442 |
Hey man, I'll try to snap some pics the next time I do Mine and Hectors switches if you want. I need to find another defroster switch for Hector. Got any 12V 3mm red LED's? I really only need one
Posts: 8,445 |
we need to use resistors in-line with these right? does the value of the resistor required varie depending upon application?
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
Posts: 9,442 |
The LEDs are all the same wattage/Volt, the power before the resistor is all 12 volt, so it should be the same resistor in all cases. I could be wrong, It's happened in the past...too much
Posts: 4,140 |
Are the blue ones around 2800 mcd as well?
Posts: 4,294 |
Originally posted by hondas_for_breakfast: Are the blue ones around 2800 mcd as well?
anwsered this in a IM, but for others 3.2k-3.6k
Originally posted by bk4293: The LEDs are all the same wattage/Volt, the power before the resistor is all 12 volt, so it should be the same resistor in all cases.
All the same, I changed them to a 510, since somebody helped me figure they needed a bigger resistor.
Originally posted by ElKy: we need to use resistors in-line with these right? does the value of the resistor required varie depending upon application?
With the new resistors I am sending out, only 1 resistor per led, depending on how you set it up. if you install it the same was as the old one, it requires 1.
Originally posted by bk4293: Hey man, I'll try to snap some pics the next time I do Mine and Hectors switches if you want. I need to find another defroster switch for Hector. Got any 12V 3mm red LED's?
12v, no, but you can install a 510 ohm resistor on the positive side of the LED, and knock it down. Check out the junk yards I broke mine on my 95 and had to redo it, best place to find them. Now I just need a 98 clock bulb till I order my LEDs.
95 SES Sold
99 SE Sport Sold
Posts: 4,294 |
Okay, found all the tutorials, doesn't seem I ever finished them, I am gonna begin putting them together tomorrow at work, and then this weekend. There is a lot of work to be done, and anyone who would like to help me write them up, or draw diagrams, would be appeciated. most of the pictures I have are from my old 95 se, I will soon be doing my new car, but the tutorial will show a different way of installing them as I will be doing a setup that anyone is welcome to copy, I have yet to figure out exactly how I will do it, but I will be doing every single light in the car, doors, switches, guages, hvac, footwell, glove box, sun/moon roof, behind door handles, key holes, trunk, dome, map lights, hood light. It will all be done, I am still figuring out how many LEDs I will need and what I need to order. I hope this will give everyone will enjoy the pictures once I am done. My guages should be done and put on by then also.
95 SES Sold
99 SE Sport Sold
Posts: 26 |
Could you tell me how much total with shipping for a pack of 25 3mm red and a pack of 25 5mm red.
