Posts: 7 |
i know this has probably been addressed before i cannot find it in search. i have been away awhile, i have a 1998 svt and have a trunk leak. what is the method for correcting this? thanks
Posts: 2,382 |
You have to adjust your search dates. Default is like 2 weeks I think Link
"Fear is the little death."
Muadib.
Posts: 1,460 |
my problem was that one of the 2 clips on this piece wasnt snapped in all the way. i used to have a river in my car. i just bent the clip up and it locked in place. no more leaky.
'99 ČoňtôúŔ SE
Kenwood KDC-MPV7019
AudioBahn AW1206T Flame Q Sub
AudioBahn 1300HCQ Amp
Blue LED Switches and HVAC
Posts: 1,746 |
Same here. It seems that the vent tends to pop loose every now and then causing a pretty bad leak. If you pull them back until they snap into place, it should(I repeat 'should') fix the leak.
Posts: 1,176 |
When I bought my car, one was missing completly. I bought two replacements and replaced both to be sure I wouldn't have any more leaks.
Posts: 328 |
In my case the leak was from around the tailight. I simply took off the light (three fasteners inside the trunk), cleaned all the mud/dirt/crud off the foam gasket, and silicone sealed it back in place. It's been fine since.
- Jim
Our yardbirds:
Belvedere, our '96 Jeep Cherokee, 4.0L ATX, 85,000 and going strong
Spencer, our '03 Chrysler PT Crusier, 2.4L ATX, 28,000 and just getting started
Posts: 1,228 |
My leak was loose bolt on factory spoiler.
There are a few lwak points that need to be checked on the Contours.
BEFORE: '99 Contour SE Sport
Duratec ATX Spruce Green
Posts: 1,960 |
Originally posted by midcoastme: In my case the leak was from around the tailight. I simply took off the light (three fasteners inside the trunk), cleaned all the mud/dirt/crud off the foam gasket, and silicone sealed it back in place. It's been fine since.
Three fasteners ? I see two, one on either side beside where the reverse light bulbs fit. Wheres the third one ?
I'll fix this trunk leak if it kills me ! .... plus I'm tired of having the trunk carpet in my livingroom for the past few months.
Bless our servicemen & women overseas.
L.Cpl Ian Malone, 1st Battalion Irish Guards, R.I.P.
Posts: 6 |
I had to apply silicone to the taillight gaskets and around the trunk vents to get all my water leaks fixed.
