#857978 01/30/04 04:12 PM
i know this has probably been addressed before i cannot find it in search. i have been away awhile, i have a 1998 svt and have a trunk leak. what is the method for correcting this? thanks
#857979 01/30/04 06:09 PM
N
N
You have to adjust your search dates. Default is like 2 weeks I think
Link
#857980 01/30/04 08:05 PM
my problem was that one of the 2 clips on this piece wasnt snapped in all the way. i used to have a river in my car. i just bent the clip up and it locked in place. no more leaky.
'99 ČoňtôúŔ SE Kenwood KDC-MPV7019 AudioBahn AW1206T Flame Q Sub AudioBahn 1300HCQ Amp Blue LED Switches and HVAC
#857981 01/30/04 09:15 PM
Same here. It seems that the vent tends to pop loose every now and then causing a pretty bad leak. If you pull them back until they snap into place, it should(I repeat 'should') fix the leak.
"...first he's gonna s*!t, then he's gonna kill us." 1999 Contour SVT Retrojunk.com
#857982 01/31/04 02:50 AM
When I bought my car, one was missing completly. I bought two replacements and replaced both to be sure I wouldn't have any more leaks.
#857983 01/31/04 04:24 AM
In my case the leak was from around the tailight. I simply took off the light (three fasteners inside the trunk), cleaned all the mud/dirt/crud off the foam gasket, and silicone sealed it back in place. It's been fine since.
- Jim Our yardbirds: Belvedere, our '96 Jeep Cherokee, 4.0L ATX, 85,000 and going strong Spencer, our '03 Chrysler PT Crusier, 2.4L ATX, 28,000 and just getting started
#857984 01/31/04 04:53 AM
My leak was loose bolt on factory spoiler.
There are a few lwak points that need to be checked on the Contours.
My name is Richard. I was a Contouraholic. NOW: '02 Mazda B3000 Dual Sport, Black BEFORE: '99 Contour SE Sport Duratec ATX Spruce Green PIAA 510's, Foglight MOD, K&N Drop-in
#857985 02/13/04 03:36 PM
Three fasteners ? I see two, one on either side beside where the reverse light bulbs fit. Wheres the third one ?
I'll fix this trunk leak if it kills me ! .... plus I'm tired of having the trunk carpet in my livingroom for the past few months.
Bless our servicemen & women overseas. L.Cpl Ian Malone, 1st Battalion Irish Guards, R.I.P.
#857986 02/14/04 08:27 PM
I had to apply silicone to the taillight gaskets and around the trunk vents to get all my water leaks fixed.
