#857437 01/30/04 01:20 AM
cel came on tonight on my way to work. autozone dude tells me it is code p0304 and then tells me it is the camshaft position senor circuit fault. only proble is that code p0304=misfire detected cylinder 4 and p0340=camshaft position sensor circuit fault. the car runs fine as i commute 100 miles to work. i am going back to autozone and look at the code for myself in the morning. has anyone had a p0340 and what does this mean exactly?
2006 fusion sel 1998 grand prix gtp(wife) 1993 dodge shadow es(winter beater)
#857438 01/30/04 01:48 AM
U
U
Diagnostic Trouble Code (DTC) P0340 indicates that Self-Test has detected a Camshaft Position (CMP) Sensor circuit failure.
First step was to clear the code and see if it returns by increaseing rpm to greater than 1500 rpm for 10 seconds and repeating two times.
From here it depends on which type of sensor you have. Hall Effect (three pin connector) or VR (two pin connector).
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
#857439 01/30/04 02:29 AM
thanks dude! i will see if autozone can clear the cel and then try this to see if the cel comes back on.
from the sounds of it this may be just a bad sensor(i hope)
#857440 01/30/04 05:46 AM
so has anyone ever replaced one of these sensors and how much?
#857441 01/31/04 12:01 AM
surely someone has replaced one of these. price is $13.00-$22.00. so exactly where is this thing?
#857442 01/31/04 02:02 AM
H
H
That depends on what you have. I have never replaced it on mine because it hasnt needed it but on a Zetec it is very simple, it is held on by two bolts that are very easy to get to.
#857443 01/31/04 02:18 AM
i have a 2000 v6 duratec
#857444 01/31/04 05:08 AM
1996 2.5LT V6 Contour ATX My Tour+help/info pics E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
#857445 01/31/04 07:36 AM
you are the MANNNNNNNNNN!
#857446 02/03/04 03:57 PM
and WOW.. if i could only get to all the parts of my engine like this.... only problem is: the firewall, the left and right sides of the sheetmetal and the front are in the way...
