Posts: 320 |
cel came on tonight on my way to work. autozone dude tells me it is code p0304 and then tells me it is the camshaft position senor circuit fault. only proble is that code p0304=misfire detected cylinder 4 and p0340=camshaft position sensor circuit fault. the car runs fine as i commute 100 miles to work. i am going back to autozone and look at the code for myself in the morning. has anyone had a p0340 and what does this mean exactly?
2006 fusion sel
1998 grand prix gtp(wife)
1993 dodge shadow es(winter beater)
Posts: 3,944 |
Diagnostic Trouble Code (DTC) P0340 indicates that Self-Test has detected a Camshaft Position (CMP) Sensor circuit failure.
First step was to clear the code and see if it returns by increaseing rpm to greater than 1500 rpm for 10 seconds and repeating two times.
From here it depends on which type of sensor you have. Hall Effect (three pin connector) or VR (two pin connector).
Phillip Jackson
`98 Mystique LS
262K+ and counting...
ATX rebuilt @ 151K
Posts: 320 |
thanks dude! i will see if autozone can clear the cel and then try this to see if the cel comes back on.
from the sounds of it this may be just a bad sensor(i hope)
2006 fusion sel
Posts: 320 |
so has anyone ever replaced one of these sensors and how much?
2006 fusion sel
Posts: 320 |
surely someone has replaced one of these. price is $13.00-$22.00. so exactly where is this thing?
2006 fusion sel
Posts: 2,725 |
That depends on what you have. I have never replaced it on mine because it hasnt needed it but on a Zetec it is very simple, it is held on by two bolts that are very easy to get to.
Posts: 320 |
i have a 2000 v6 duratec
2006 fusion sel
Posts: 2,017 |
1996 2.5LT V6 Contour ATX My Tour+help/info pics
E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
Posts: 320 |
2006 fusion sel
Posts: 888 |
and WOW.. if i could only get to all the parts of my engine like this.... only problem is: the firewall, the left and right sides of the sheetmetal and the front are in the way...
