#856493 01/29/04 01:50 AM
GoSox Offline OP
I bought my car almost a month ago. It's had its Washer fluid resivouir and motor replaced and at that time I had the hoses flushed and cleaned out. Since then, a puddle of red/pink fluid (transmission fluid) has been making leaking enough to cause a puddle to form, but the amount of fluid left is still too much where I can add any. Could this just be because of the -20° weather with a cracked hose, or could it be from the dealer? and, can I fix it myself if it just requires replacing a hose?
1998 Black, Contour GL. 89,098 on the clock.
#856494 01/29/04 01:55 AM
H
H
Check the transmission gasket for leaks.
Make sure all bolts on it are tightened to 18 foot pound I believe it is.
#856495 01/29/04 02:03 AM
U
U
Also check you power steering res. We use ATF there too, so it might be that instead of the tranny. If not the res, it could be a line going to the rack-n-pinion.
Which side of the car is the puddle forming?
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
#856496 01/29/04 03:18 AM
2
Not too far from the washer bottle are the lines and hoses for the Tranny cooler - if you have an ATX. Maybe they are loose/damaged?
