Posts: 294 |
How much longer?
'04 Cobra Convertable!!
Posts: 131 |
we are waiting for the rest of the shifters and the plates.as soon as they all aive they will be out.hopefully not much longer.
(2)1994 mustang GTs 2001 gt convertible loaded.www.haywoodspeed.com
Posts: 2,807 |
Do we have install instructions somewhere for the smaller 2 part tower?
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
Posts: 1,423 |
Originally posted by RayL5480: we are waiting for the rest of the shifters and the plates.as soon as they all aive they will be out.hopefully not much longer.
Plates are getting shipped today (to Ray's shop)...he should have them Thursday or Friday.
Thanks for your patience, Scott
Scott
2000 Contour SVT #1464
Mustang Dyno: 171.6hp/145.3lb
Dynojet Dyno: 171.1hp/148.9lb
1989 20th Anniversary Turbo T/A "Indy 500 Pace Car"
#1376 of 1550 All Original, 46k with a few mods
2002 F150 SuperCrew
Posts: 1,785 |
Originally posted by SVTCANUK: Do we have install instructions somewhere for the smaller 2 part tower?
There should be instructions in the box and installing the plate is simple. It just sits right on top. See pics in thread.
Just a Plain SE.
AKA Big Country
I maybe path914's B**** now, but wait until he needs his clutch done. We will see WHO is WHO's B**** then!
Posts: 6,910 |
Originally posted by myfastse: Originally posted by SVTCANUK: Do we have install instructions somewhere for the smaller 2 part tower?
you only end up using half the direction since they are for a focus but the directions are easy to follow
only thing the directions don't cover is you need to either remove the centering spring or notch the tower so that the centering spring will work.....you will see what I mean when you try putting it in with the spring installed and the plate.
The plate riases everything so that means the spring is higher and cannot enter the cutout that was originally made for it
yes I know everyone says remove the spring but it works fine with it
also the focus 2-3 assist spring that comes with the shifter also isn't needed
- 95 Mystique LS - Zetec/5spd
Posts: 2,807 |
Will I still need to get under the car and remove the heat shield for the install with the smaller plate? Logic tells me no because of where the small plate is installed relative to the larger plate for the one piece towers.
99 CSVT Green/Tan
# 84 of 2760
75,000Km
96 Contour GL
Posts: 6,910 |
the small pate goes right under the shifter on top of the tower, only the larger plate for the 2000 do you need to get under the car
Posts: 2,807 |
Originally posted by brapple: the small pate goes right under the shifter on top of the tower, only the larger plate for the 2000 do you need to get under the car
that makes me !
99 CSVT Green/Tan
# 84 of 2760
75,000Km
96 Contour GL
Posts: 131 |
ok guys the plates should arive by friday,i have 15 shifters now,the rest should be here by next week and the first batch should go out monday.
