Page 9 of 35 1 2 7 8 9 10 11 34 35
Just out of curiousity, whats the hold back on this? More people or the plates? Thanks.
Justin Schmidt 2000 SVT Tour #1620 of 2150 Born 1/15/2000
Eric (myfastse) is running the GB but hasn't posted here for about 10 days? I think the goal was to get 20 same as the last GB to get the same price. He needs to post a list of who is in and what plate they need. I made the plates for this GB. I have 16-pre-2000 model plates and 6-2000 model plates fabricated and ready to ship. I'm just waiting on Eric and Ray at this point. Ray (Fastlane Motorsports)is the guy that got us the deal on the last GB.
Scott
Scott 2000 Contour SVT #1464 Mustang Dyno: 171.6hp/145.3lb Dynojet Dyno: 171.1hp/148.9lb 1989 20th Anniversary Turbo T/A "Indy 500 Pace Car" #1376 of 1550 All Original, 46k with a few mods 2002 F150 SuperCrew
Originally posted by FreeProjectPat:
So, with 98's and 99's, getting under the car isn't required? I'm still in regardless, just wondering...
Nope...all done from the top. I think the hardest part for the 98-99 guys is getting the console out and it's not that hard After you do the job one time you will see that it can be done in as little as 20 minutes. That's how simple it is.
The 2000 guys will have to get under the car and behind the heat shield so this will add 20-30 minutes to the job. Still very easy.
Scott
1
Awesome...Last time we did a list we had over 15 people, and more have said they want in since then...We should be good to go, right?
yeah, but some have dropped out too...we will have to wait and see what's up with the guys running the GB.
Scott
hey guys,eric and i have been up to our eyeballs with work.we are still on top of things
(2)1994 mustang GTs 2001 gt convertible loaded.www.haywoodspeed.com
1
Hey Ray what part of NC are you from?
hey pat we are located in Raleigh,about 1 mile from the fairgrounds.
Ok guys...I received a PM from Ray last night, Eric has had a family situation that he is dealing with. That is why he has not been on-line and not responded to this in a while so please be patient.
What I need from all of you is to have this list verified and updated with the plate type you will need so that we have the proper amount of both type plates we need to complete the GB. This is just a list that I copied from a few pages back so it may not be very accurate so add, remove, update or whatever is necessary to get it right. Be sure to check your shifter tower before you pick the plate you need. You can easily pop off the ring around the boot with a small screwdriver to get a quick look at your shift tower and determine which plate you need.
If the top of your shifter tower looks like this (ignore the shifter part since the Steeda is already installed) YOU WILL NEED THE LARGER 2000 MODEL PLATE.
All others (some 2000, 1999 and older) will need the small plate.
1) path914
2) Speed Demon
3) papadage
4) 99SVT
5) dorf tourcon
6) SvtinAtl
7) Keyser
8) FreeProjectPat
9) KTPDave
10) thjms
11) Antonio
12) jshimer23
13) Morbid(maybe)
14) KingPinSVT(maybe)
15) Maverick
Thanks for your patience.
Scott
Morbid = definite and I have a 2000, 1 piece tower. Thanks!
morbid 2000 Contour SVT (black)
Moderated by  1314_dup1
