Ok guys...I received a PM from Ray last night, Eric has had a family situation that he is dealing with. That is why he has not been on-line and not responded to this in a while so please be patient.
What I need from all of you is to have this list verified and updated with the plate type you will need so that we have the proper amount of both type plates we need to complete the GB. This is just a list that I copied from a few pages back so it may not be very accurate so add, remove, update or whatever is necessary to get it right. Be sure to check your shifter tower before you pick the plate you need. You can easily pop off the ring around the boot with a small screwdriver to get a quick look at your shift tower and determine which plate you need.
If the top of your shifter tower looks like this (ignore the shifter part since the Steeda is already installed)
YOU WILL NEED THE LARGER 2000 MODEL PLATE.
All others (some 2000, 1999 and older) will need the small plate.
1) path914
2) Speed Demon
3) papadage
4) 99SVT
5) dorf tourcon
6) SvtinAtl
7) Keyser
8) FreeProjectPat
9) KTPDave
10) thjms
11) Antonio
12) jshimer23
13) Morbid(maybe)
14) KingPinSVT(maybe)
15) Maverick
Thanks for your patience.
Scott
