Posts: 1,165 |
Man I've been waiting for months for this GB and now I may have to back out.
My car has just been nothing but problems and today it won't start again. This is like the last straw. I'm going to try to get rid of this car ASAP if i can.
I live in Detroit, I couldn't give a **** how good my car is in the "twisties."
"I could use a hundred people who don't know there is such a word as impossible."
~Henry Ford
Posts: 1,423 |
I hope this wasn't all for nothing These are the two different plates we have been referring to. The 99 and older models will typically use the small 1/4" thick plate on the top of the shifter tower. The 2000 models will use the large 1/8" thick plate that goes under the car on the bottom of the shifter. Sorry it took so long, been real busy  Scott
Scott
2000 Contour SVT #1464
Mustang Dyno: 171.6hp/145.3lb
Dynojet Dyno: 171.1hp/148.9lb
1989 20th Anniversary Turbo T/A "Indy 500 Pace Car"
#1376 of 1550 All Original, 46k with a few mods
2002 F150 SuperCrew
Posts: 70 |
so how much will it be for everything w/ plate and w/o plate and what is the advantage of having this and having it wit the plate and wit out the plate please explain and let me know thanks
Posts: 1,165 |
Originally posted by scottd60: I hope this wasn't all for nothing
I'm still in. I was just pissed. Maybe this car won't piss me off so much if it had a nice shifter.
~Henry Ford
Posts: 5,600 |
hmm, i *MIGHT* still be in. i really want to, but i am going to have to work out some financials first. ill give a for sure or not soon.
Black 1998.5 CSVT
Posts: 265 |
i'm still in
01 Black Honda S2000
99 svt Tred/tan
#2394 of 2760 on July 29, 1999 *SOLD*
Posts: 903 |
Originally posted by jshimer23: i'm still in
Posts: 2,241 |
Originally posted by thejms: Originally posted by jshimer23: i'm still in
-Matt
"Pain heals, chicks dig scars, and glory lasts forever!"
will do/pay just about anything for the following parts:
CF sunroof glass replacement
OEM CF trunk
Non OEM style cf or fiberglass hood not the cf1 design
Posts: 1,423 |
Originally posted by quicksilver_svt: so how much will it be for everything w/ plate and w/o plate and what is the advantage of having this and having it wit the plate and wit out the plate please explain and let me know thanks
Haven't heard from Eric in a while but I think the price is around $105 shipped?
The plate is required for the shifter to work in our cars. The shifter is really for a Focus but with the use of one of the plates it works perfect. What plate you need depends on the type of tower you have. All pre 2000 and some 2000 models will use the smaller 1/4" plate and most 2000 models will use the larger 1/8" plate. The Focus has a taller shift tower then the Contour...the plates make up the difference and allow the shifter to fit and function properly. It will not work without them. Both installations are very easy. The 2000 model requires a little more work only because you need to get under the car and get behind the heat sheild (does not have to be removed completly). It can be done in less then 1 hour. Pre-2000 models have been done in less than 30 minutes.
Scott
Scott
2002 F150 SuperCrew
Posts: 1,012 |
So, with 98's and 99's, getting under the car isn't required? I'm still in regardless, just wondering...
