Originally posted by Remy:
I have noticed a speaker cut out in the rear deck though with the holes already there. What is that for and why is there only one of them? What size speaker will fit there anyway. So you guys don't think the back speakers do much? I think it makes the music sound more full and louder. I know you can bairly hear the rear speakers over the front so what about putting 3 way 6x8's up front and 2 way 6x8's in the back would that sound good? Plus I was wondering if the tweets from a Mach 460 system from a Stang would fit our Tours in the same place? If not would that be a good location to mount surface mount aftermarket ones? Oh yeah I have a Lightning Audio 150watt amp would that sound good with the regular speakers? It rocks the hell out of my 10" Pioneer, I think the amp is under rated just like Rockford Fosgate's they are made by them anyways. But do you guys think that would be a decent setup? Two tweets on the inside of where the mirrors are, 2 3 way 6x8's in front doors and 2 2 way 6x8's in the rear doors?
The hole in the rear deck is for a subwoofer that was used in the Mondeo. The diameter is 6.5" which is about the same size as the cone diameter of a typical 8" driver.
As far as the rear speakers, I always have used some type of fill for the rear, but you can't tell they are there. Whenever you have sound coming from the rear that is noticeable, it is bad for the soundstage. If you have a mobile video system with some sort of surround sound, they are necessary, or if you just want to upgrade the stock system without going to crazy, it's not a bad idea to run rears. Especially if you often have rear passengers.
