#85109 01/21/02 07:17 AM
I
I
I'm considering doing a custom built setup for my subs in my car. The port here would be behind the armrest in the back seat. When the rest is down, you'd be able to look back and see the speakers. And since I haven't got hosting and images on here down yet, prepare for text drawing. smile hahaha
___ ___
\_{_}_/
____________| |____________
The * mark where the face of the subs would be.
At the ~~~ I planned on putting a design of some sort on the inside of the box, so when someone looked back, they'd see it. The entire setup would be taller than the gap the armrest hides, so some sort of lighting would be done from the ceiling of the box to illuminate it all. My thought was a Cadillac Emblem where the ~~~ are, and a black light might look good. But, I'd like to know what people's theories on it's sound would be like. I don't do astounding amounts of power, and want a clear, crisp sound in the lower volumes. Friction thinks this setup may create an audiopass which would give me high volume and hard hit, but both at high levels. Any other theories?
Words of wisdom...
-I'm too old for this sh*t.
-Dirty jews have well laundered money.
My car: Alyssa
1997 Cadillac Eldorado
Silver w/ Black half top
Ravin mufflers
Modified airbox and MAF
Rockford Fosgate 258 Watt multi channel Amp
Rockford Fosgate 9300X Punch Headunit, MP3 disc, with 8 CD changer.
Pair of 12" Boss 250W speakers in an oversized box
14.730 sec @ 95.79 mph in overdrive.
DYNO! 236.2 FW STD Horsepower
292.8 FW STD torque
#85110 01/21/02 07:21 AM
F
F
He means this, guys:
-Chris
Chris Hinds
AIM:CJ111010
1998 Contour GL Duratec 5-Spd
#565/????
15.610 @ 89.62mph
And I payed for it all myself
#85111 01/21/02 07:24 AM
I
I
Dammit, it scrunched up my drawing. Lets try outsmarting this thing
___ ___
\_{_}_/
____________|000000000|____________
|00000\000000000000000000000/00000|
|000000\*00000000000000000*/000000|
|0000000\*000000000000000*/0000000|
|00000000\*0000000000000*/00000000|
|000000000\00000~~~00000/000000000|
0's are spaces. This is an attempt, though Friction's telling me a way to fix it.
Words of wisdom...
My car: Alyssa
Ravin mufflers
292.8 FW STD torque
#85112 01/22/02 03:16 AM
I am not 100 percent sure on this but i do know that when you use ported or enclosed boxes the dimensions have to be within range for the specific speakers or it could cause damage. I know that when it comes to enclosed or closed boxes it is more improtant to follow the size restriciton, bu it is also important with ported. If you are very familiar with this stuff then i am sorry for wasting your time. I alwasy consult one of those guys and small radio install shops they usually have good clues... good luck anyways.
#85113 01/22/02 05:43 PM
I
I
The enclosure is actually going to probably be bigger than the 12's will need. And I'll probably have small ports drill so it dumps into the trunk. I'm just trying to find out how that's likely to sound.
Words of wisdom...
My car: Alyssa
Ravin mufflers
292.8 FW STD torque
#85114 01/22/02 06:47 PM
Ports have to be tuned for the enclsoure/speaker being used. Be careful about how your port the speaker, it is a very specific science.
#85115 01/22/02 09:32 PM
I had a setup similar to this in my last car (Infiniti G20, R.I.P.) Fired through the armrest skihole, and it sounded LOUD...but, if not built perfect, you can end up with a one note wonder...make accurate mesurements, and you should be fine...btw...mirrored glass along the floor helps the lighting...just my .02
Ride: 2000 T-red SE
Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE
Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
Moderated by  dnewma04_dup1
