This is a general kind of question for my knowledge if someone doesn't mind giving their input.
After getting some tire spin on the ice yesterday i noticed a clutch burning smell. I've always wonderd why if the clutch is contacting with the flywheel properly and the 2 are not slipping against each other, what causes the clutch smell? Is it just the wheels spinning to quick, and overheating the tranny in general? I know the clutch packets (which i don't know much about) of an auto are more tempremental then the clutch of a standard trans so I was just curious....
2000 Contour SE Sport V6 Duratech Alpine MP3 CD Head unit 20% tint AEM Short Ram Intake
there is no clutch holding it to the flywheel
there isa torque convertor which is bolted to teh flywheel
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
If your Contour is equipped with Traction Control,
what you are smelling could be your BRAKES.
Pete... 2004 Mercury Marauder 300A Black Clearcoat/Dark Charcoal LEATHER DOB 10/31/2003 DOP 1/2/2004 www.mercurymarauder.net
Thank you for your answers. I'm thinking it was maybe the torque converter clutch after reading my ford service manual and hearing some of your answers.
You would not smell the TQ clutch. It is inside the TQ in the oil. Check your oil. If it is brown and/or smells burnt, change it immediately.
Do you have Traction Control?
Was your e-brake dagging? (The sometimes freeze up from water in the cable)
A burning clutch smell on an automatic trnsmission car is usually the brakes.
My name is Richard. I was a Contouraholic. NOW: '02 Mazda B3000 Dual Sport, Black BEFORE: '99 Contour SE Sport Duratec ATX Spruce Green PIAA 510's, Foglight MOD, K&N Drop-in
This car is non traction control. A friend had suggested to me too that it could have been the smell of the tires heating up against the ice as they spun.
I'll check my transmission fluid today and make sure it hasn't been cooked, good call.
