TonyD Offline OP
If anyone here makes custom sub enclosures can you please let me know!
I am looking for one of these options for my 2 8" a/d/s
a) suspended box in rear deck
b) box fited in spare tire well (prefered method)
c) box fitted in each corner of the trunk.(closest to end)
I need my trunk space for a wheel chair so you can see my problem with space.
Maybe i'll have to settle for 1 8" sub.
Thanks, oh yea don't forget to quote me $ :p
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
Sound by Crystal Mobile
Powered by a/d/s M860 AMP
My Ride
Tony, I will Get on The cad program and see what i can come up with. Any idea min. and max air space those things need? that would be a big help.
2000 SE Sport MTX
Current Mods:KKM intake/removed res./custom Flowmaster exhaust/Eibachs/SVT struts/17x7 TSW imolas w/Dunlop SP9000 tires/fog fix/885 fogs/sound by Alpine,PPI,Audio Control,JL Audio,Boston Acoustic,Focal/Schroth 4-point racing harness.
Future Mods: Fully Zaino'd/front and rear sway bars(w/ custom BNOON powdercoating)/Strut tower brace/SVT exhaust/underdrive pulleys/SVT upper and lower intakes/Superchip/B&M short shift/SVT front bumper/and some others I haven't decided on yet.
www.stlsp.com
"Life's too short not to spend money----on your car!!"
"It's only wrong if you get caught doing it"
FYI, my enclosure fits 2 x 10" JL Audio subs, it's 8 layers of fiberglass molded to the spare tire well. The MDF baffle fits flush with the trunk floor. The trim piece that finishes it off raises the whole thing another 1" to include grilles that protect the subs. I have spacers on either side to level the floor off and the stock carpet fits over the whole thing. It weighs 15 lbs more than the spare / jack combo which is not bad at all...
Here are various stages of the buildup, it's not upholstered yet... But it sounds pretty good for something that you can't see!
Dynamat inside the box
Mounting the baffle and filling in the gap
The assembly in the trunk, fits flush with the lowest points of the floor
Filling in screw holes + initial testing (note the polyfill in the box)
Weather stripping to prevent air leaks
Drivers mounted, surfaces smoothed out, awaiting upholstery
The $$ issue:
- Cheap subs 200$
- Leftover MDF at Home Depot 5$
- Fiberglass supplies 50$
- Countless hours... did everything myself
TonyD Offline OP
timfiredog I posted specs HERE
Silversvt I wonder if it would be posible to make a floor outta ply wood with an MDF box for the 2 subs attatched in the spare tire well?
No fiberglass needed, possible better sound as well as ease of construction.
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
My Ride
holy cow! i never looked under the carpet to see how HUGE that space is!!
looks great!!!!
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
The $$ issue:
- Cheap subs 200$
Curious how they sound? Any rattles? More/less?
Do you notice your loosing usable floor space in the trunk or have you placed plexiglass over it?
Do you gain more bass by this mounting method...
I currently have a SQ setup and am looking at different ways to build a new enclosure....Currently I have the subs facing the front, which works for me. Although I feel I'm loosing some low end bass by doing this.
What are your thoughs?
Oh by the way Nice job on that! Very professional!
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
This is pretty similar to what I had. If you had your subs mounted facing the rear seat without modifying the rear seat, this method will probably gain you a dB or so. If you had the subs facing the rear, you might lose a dB. I found it to be the perfect location for my listening tastes.
silversvt,
great job on the enclosure! that looks very professional!
TonyD Offline OP
No takers eh!
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
My Ride
TonyD Offline OP
Silversvt if you could send me a how to i would appreciate it. Anyone have any idea what type of box would help as well.
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
My Ride
Moderated by  dnewma04_dup1
