I used to have a good picture pointing out the hidden screw locations, but Photopoint went bye-bye. So, bear with my memory. There are two screws behind the door pull handle which is covered. One screw behind a little cover in the lower front corner of the door, and one screw behind a little cover near the door opener lever. You have to remove the defrost vent cover before removing the door panel for which there is just one covered screw. Plus the 4 or 5 around the outside exposed. I don't remember any by the lock switch. Once you have the door panel off, you'll have to unhook the power window switch connector.
