Posts: 217 |
i ask because my brother had his system test two weeks ago and he had 160db is his Cr-v. And he only has two audiobahn suub and he does not have the most expensive stuff. And he say that it need some more.
'98 Contour se V6 auto Blue headlight,foglights, and green backup light and green underbody neon Clarion Pro Audio headunit 6x8 Audiobahn up front 6x8 Infinity Kappa in rear all new system coming soon slimshorty42@hotmail.com
Posts: 8,142 |
Depends what you are doing. For everyday listening he is about 32x as loud as a comfortable volume needs to be. If he competes in SPL competitions, he may or may not need to work on it some more.
Can you tell me specifically what he is running?
Posts: 217 |
this is just for listening to right now and he might get in to SPL competitions. And i might if I ever get my system done.
Posts: 918 |
If I may ask, how did he measure that he has 160db in his CR-V? Did he compete in a db Drag? Does he know someone that owns a car audio shop? To answer your question, no, you can never have too much.  I am also curious on what he is running.
************************* 2000 SE Sport V6 Deep Navy CC Metallic My 2G Sport *************************
Posts: 869 |
you only need to know that it's audiobahn nick!
2000 CSVT #1172 of 2150 Toreador Red...Birthday -> 1/4/2000 *Indiglo Gauges *Drop in K&N *Sylvania SilverStar Highs in Lows *Fog light Fix *Pioneer Premier P730 *Sound by Audiobahn *White HVAC Panel *Security via Ungo MS2007 *Elky Mesh Mod
Posts: 918 |
Hahahahaha!
Posts: 8,142 |
The two audiobahn subs are the reason I am questioning the ability to hit 160 dB.
Posts: 1,032 |
Originally posted by dnewma04: The two audiobahn subs are the reason I am questioning the ability to hit 160 dB. What if he had a pair of these and 10,000 watts rms??? [img] http://store6.yimg.com/I/competitiondirect_1657_55328701[/img] Audiobahn AWT34 34" Linear Compression Subs 650oz Double Stacked Strontium Magnets | Power Handling: 5000 watts R.M.S. | Frequency Response: 10Hz – 400Hz | Efficiency: 88.9dB | Bolt Tight Motor Structure | PHAT 2 Inch Foam Surround | Titanium/Aluminum Cone | 5 Inch 4-Layer AVS Voice Coil | Dual 2 Ohm Voice Coils | 1 Ohm or 4 Ohm Operation | Mounting Dimensions: Depth; 12 Inch Diameter; 34 Inch
1999 SVT #900/2760 Born on 1-20-99 Silver Frost/Midnight Blue A few aesthetic and audio mods
Posts: 8,142 |
it would requires somewhere on the order of 30dB of cabin gain to reach 160 db with those subs.  I don't think that would be happening...
Posts: 869 |
Dnew- Why do you hate audiobahn, and push home speakers on everyone(daytons)? I ask cause you seem to know a whole bunch about car audio, I'm a newbie in the realm of car audio, but audiobahn was the best quality I could get at a bargain price. I've heard a lot of people on sounddomain that hate audiobahn(that don't run them), but everyone I talk to that run's their speakers/amps loves em. Am I missing something? (probably am...)
