Posts: 228 |
Originally posted by MarkO: I have heard too many contradictory posts about putting Dexcool in to a system that previously ran on non Dexcool coolant. Some say yay, some nay. Why risk it?
Yeap, I was about to do that beleiving Dexcool was the upgrade to the Green stuff, but other CEGers flamed at me, so I didn't do it.
Wondering if someone else did it with no problems.
Pablo Quintana
98 SE Sport Contour
Honduras, Central America
Posts: 1,605 |
I've done it... about 15k miles on it along with new pump housing, metal waterpump, belt and new pully.. Mine seems to run cooler, never passes O in NORMAL, that could also be because of my 180 degree thermostat.. who knows
#3162 of 6535
98 SVT Silver frost
Viper Responder 791 w/ 2way remote start
Let the modding begin!
Posts: 65 |
It is a bear flushing the system out because the Duratec does not have a block drain. If you use the distilled water as one suggested it will take awhile. By rights when you fill the system with straight water you should run the engine up to temperature with the heater on to clear the heater core of the old coolant.
'98 LS MTX
Posts: 429 |
Even though it is a tedious process, I would go the distilled (or DI) water route. Again, this procedure minimizes hardness in the cooling system which is the culprit for scale and even water pump seal erosion. BTW, I have been using DEXCOOL for over 5 years now (changed it once already), with no problems whatsoever. In my opinion, the bad DEXCOOL rap is somewhat the same as the now dead synthetic oil rap. Something new and promising always meets with resistance and suspicion.
Dan B.
96 SE 2.5 auto
Posts: 1,960 |
Thats good info. I wasn't being a luddite in my initial post. There will always be naysayers when something new comes along but the debate seemed to be 50/50 for and against on Dexcool.
Bless our servicemen & women overseas.
L.Cpl Ian Malone, 1st Battalion Irish Guards, R.I.P.
Posts: 4,639 |
sorry for rehashing this. where would i get distilled water. what do u guys do with the old coolant. throw it away?
Hugo AIM:omegazodiac
Posts: 119 |
I always buy the distilled water at the grocery store. It's by all the bottled water. Just make sure you don't buy the "drinking water" instead; that still has some stuff in it that will leave scale.
Posts: 4,639 |
thanks. i never knew it was sold at grocery stores. i'll go take a look
Posts: 596 |
I had a problem with my high speed fan coming on all the time. I did the waterpump and thermostat as it went in the middle of this. Still had only high speed come on.
Checked the relay, the fuse and it was all good. It ended up being a resistor and my high speed fan problem was solved. Unfortunately when we removed the plastic shield under the rad as we were changing the resistor we noticed it was leaking coolant from the passenger side of the rad, from the left tank. Now I have to change the rad. My car only has 77000kms any idea why this would have happened.
1999 Silver Frost Contour SVT
2690 of 2760 Born 08/13/1999
Sony Mobile ES CDX-C90 Deck
6 1/2 Infinity Kappa Perfect mid & tweet set, 2 12 Infinity Kappa Perfects JBL P.600.1 for Bass, P.180.2 for front stage.
Posts: 635 |
Originally posted by Alex T.: I had a problem with my high speed fan coming on all the time. I did the waterpump and thermostat as it went in the middle of this. Still had only high speed come on.
If there is no visible damage, I would guess you plain and simple got a weak one from the factory. I am sure they replaced the coolant when they did the engine swap, so I can't imagine it being anything related to crud in the system. Erik
