Page 2 of 2 1 2
http://www.abpco.com/AC-DC_PFC_Converter.html
the model you would want would probably be the ABP.AC.12.1600W/M-PFC no prices listed but it'll be a lot!
They are JL 12W6 dual 6 ohm running in parrallel. So it is at a 3 ohm load and is already in a sealed box. The box was built to spec from my loacl installer. I know it would be better if I had a ported enclosure, but I'll live with what I have. I sent an email inquiring on the price of those invertors you listed, both the 12 volt and the adjustable 10v - 26v. Thanks for the info. Thx!
-SVTweeter-
http://svtitan.com - view the Ride!!!
98.5 Black SVT
PIAA blue platinum fogs,CATZ MSC in factory fog holes 18x7" Chrome Neeper Titans
KKM Induction, (4) 15 inch Solo-baric L7's in the trunk, (2)Earthquake PHD2 amps, Memphis 3004 powering (4) kicker 6.5 subs in doors,
Imaged Dynamic CD2 Horns powered by Memphis st150 amp.
5% tint around, side markers, Bassani exhaust, Ground Control Coil-overs w/ Eibachs,
Koni Struts & blackened back Reflector, B&M shifter
148.7 db May 6th - DB Drag
Yet to drag with new amps ... can't wait
shopping cart spoiler - I can fly baby!
APT Offline
for the cost of a quality inverter, you're better off just selling your amp and getting a home amp. Something like two plate amps Dave mentioned or a rack component.
OK, do you guys know who makes some good plate amps? I don't have a clue, but would like a 800w amp or so. The box I have only has 1 input for wires, not one to each sub. Do plate amps plug into the wall-outlet or would I still need the inverter to make this work. Thx!
-SVTweeter-
98.5 Black SVT
APT Offline
Plate amps plug into the wall and unless you open you box to get another set of wires out, I suggest a rack amp.
Somthing like this will do.
check this THREAD
some of these amps are AWESOME and he has amazing prices....
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
Page 2 of 2 1 2
Moderated by  dnewma04_dup1
