Posts: 8,142 |
http://www.abpco.com/AC-DC_PFC_Converter.html the model you would want would probably be the ABP.AC.12.1600W/M-PFC no prices listed but it'll be a lot!
Posts: 135 |
They are JL 12W6 dual 6 ohm running in parrallel. So it is at a 3 ohm load and is already in a sealed box. The box was built to spec from my loacl installer. I know it would be better if I had a ported enclosure, but I'll live with what I have. I sent an email inquiring on the price of those invertors you listed, both the 12 volt and the adjustable 10v - 26v. Thanks for the info. Thx!
-SVTweeter- http://svtitan.com - view the Ride!!! 98.5 Black SVT PIAA blue platinum fogs,CATZ MSC in factory fog holes 18x7" Chrome Neeper Titans KKM Induction, (4) 15 inch Solo-baric L7's in the trunk, (2)Earthquake PHD2 amps, Memphis 3004 powering (4) kicker 6.5 subs in doors, Imaged Dynamic CD2 Horns powered by Memphis st150 amp. 5% tint around, side markers, Bassani exhaust, Ground Control Coil-overs w/ Eibachs, Koni Struts & blackened back Reflector, B&M shifter 148.7 db May 6th - DB Drag Yet to drag with new amps ... can't wait shopping cart spoiler - I can fly baby! *****************************************
Posts: 4,585 |
for the cost of a quality inverter, you're better off just selling your amp and getting a home amp. Something like two plate amps Dave mentioned or a rack component.
Posts: 135 |
OK, do you guys know who makes some good plate amps? I don't have a clue, but would like a 800w amp or so. The box I have only has 1 input for wires, not one to each sub. Do plate amps plug into the wall-outlet or would I still need the inverter to make this work. Thx!
Posts: 4,585 |
Plate amps plug into the wall and unless you open you box to get another set of wires out, I suggest a rack amp. Somthing like this will do.
Posts: 4,476 |
check this THREAD some of these amps are AWESOME and he has amazing prices....
Todd Christ SVT Contour Registry MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator '98 E0 SVT Contour #1037 of 6535
