Posts: 38 |
Hey well I'm starting the work on my A-arms. I read alot about it and after talking to Bill, I think I going to go with, lifting the tranni instead of lowering the subframe. I will let you guys know of the process.
Jose 97
Former owner of 97 SE T-Red 24V MTX built 4/96 Distroyed on 11/03!
SHE'S BACK !!!!! but was never the same!!!!
BMW 95 5er and new to the addition 92 GSXR (my very own crotch rocket)
Posts: 4,777 |
that sounds like a way better way to do it- I lifted my engine/tranny when i replaced my motor mounts- it was really easy-
dropping the sub-frame sound way to intense
Posts: 4,970 |
That's what kept me from doing my clutch the first time around....before I knew the engine/trans would come out the top.
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 3,335 |
I almost completely pulled mine when I replaced the oil pan gasket. If I could have closed the hood, my exhaust manifold would have probably been visible.  IIRC, Dave pulled his through the top when he blew his engine. Perhaps he could give you some pointers?
· Jon Miconi
· Coming Soon!
· 01 Cougar
· 98 V70R
Posts: 4,970 |
Pointers for me Jon? The pointers I need are how to cope with an engine/trans-less SVT  Ohhhhhh....it's time to go rock back and forth in the drivers seat and bable for a bit
Posts: 38 |
Well I hit a bump, the tranni does not go up far enough to clear the middle bolt, the tranni keeps hitting the sheet metal, I need to push the tranni towards the passenger side, and jack it up at the same time, so I just need to wait untill someone is off work.
Then the last bolt will come off, and I'll be done. The passenger side is out, it took me about 15 minutes.
Well I'll keep you guys posted.
Jose 97
Posts: 3,335 |
I did get your pics, Jose. I just need to upload them.
· Jon Miconi
· Coming Soon!
· 01 Cougar
· 98 V70R
Posts: 4,777 |
LMAO!!!!!!
Only Auto-Minded individuals (read carnuts) would get what you just said- to me - it made my day!!
Posts: 231 |
Dropping the subframe wasnt to hard. I just used jackstands in the rear and lowered the front with a floor jack. It takes 2 people but wasnt to intense. You definitely dont have to do everything the manual tells you to. I left the steering and power steering all together with no problems.
00 Black SVT #1545
Ground Control. Koni. 18 Konig Tantrum. More.
Posts: 38 |
I tryed to remove the subframe bolt but the front one would not move. I have an impact gun, and even with that the bolt would not move, so I stoped before I broke it, and had to fix some thing else.
Jose 97
