Posts: 2,426 |
E checks are a real pain. I've lived with it here in northern Ohio for as long as I can remember. We have to do it every other year and it's about $20. I've heard that MSDS headers are a problem, good to see they probably aren't.
Cool Toe Chris
Cool Toe Chris
Posts: 1,825 |
Originally posted by wa2tuff: E checks are a real pain. I've lived with it here in northern Ohio for as long as I can remember. We have to do it every other year and it's about $20. I've heard that MSDS headers are a problem, good to see they probably aren't.
I think NJ has a harder emissions test that OH. I've passed twice (every other year as well) with my headers and the underbody cat.
Chris
NJ
98.5 SVT Silver Frost
Posts: 1,603 |
The very first 2 years of Emissions Inspections is guaranteed by the Vehicle Manufacturer. So unless your car is more than 2 years old, it shouldn't go to anyone other than your dealership.
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 661 |
Everyone seems to be talking about PA here. NY just started this new testing and I don't know if this is exactly what you are all talking about. I heard that when the computer is hooked up that it is actually monitoring whats going on. So this made me think that if you have o2 simulators on that it might not pass you because they are not oscillating like they should. Just wondering if anyone in NY has tried this and what the result is?
Fast Cheap reliable
Pick two
Posts: 3,065 |
Originally posted by obicanobi0: Everyone seems to be talking about PA here. NY just started this new testing and I don't know if this is exactly what you are all talking about. I heard that when the computer is hooked up that it is actually monitoring whats going on. So this made me think that if you have o2 simulators on that it might not pass you because they are not oscillating like they should. Just wondering if anyone in NY has tried this and what the result is?
NY, IIRC, is going to hook a computer device to your tailpipe and see what is coming out. They also hook an OBD-II scanner up to your ECU, and check for codes. Any codes pop up, you lose the inspection sticker on the spot. As far as O2 simulators, I'm not sure, but if they aren't throwing codes or causing bad emessions, it shouldn't be a problem. Go to a garage/mechanic that knows you. Oh, and they are charging 2 times the original price, so about $35 a year for an inspection now... worse than registration.
Posts: 661 |
Yea my dad is a service manager at a shop and he wasn't sure about the 02 simms. I think its just the NYC area that does the pipe sniffer and that cost the $ ur talking about. no sniffer around here and it cost $22.
Fast Cheap reliable
Pick two
Posts: 4,292 |
if you read through the nys inspection laws it states that you cant be failed for your check engine light coming on if it doesnt involve a part of your emissions system...but you can be failed if the cel doesnt come on when the car is first started....obi is also right about not having the sniffer test in upstate ny..not yet anyways.....i've also heard that if you fail the inspection and the shop says it's going to cost more that 800.00 to makethe car pass the test you can get a one year waiver from the state to fix it....but you only get one you cant keep doing it from year to year.. i'm do in april worst comes to worst i'll "sell"  it to my aunt in pa, get the 5k or less a year waiver and call it good!!
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 367 |
Originally posted by I8RICE: just got back from the emmisions stations today and passed with flying colors not a single prob.
my mods are as follows
msds headers and y pipe custom exhuast superchips cpu chip underdive ps pulley magnacore race wires pro m mass air meter k&n cold air intake svt throttle body on non svt intake that is port matched with opened egr runners running 93 octane in car as well
Are you still running a main cat?
98.5 T-red SVTour
05 Blue Yamaha R6 for sale PM me
Posts: 3 |
Ok guys, i thought i would put my 2 cents in. I am a service writer for a large Toyota dealership near Philly. Pre 1996 cars still get put on the rolling dyno, and get run through the full exhaust sensor testing. 1996 and up simply get an emissions computer hooked up directly to the cars on board diagnostic port. The most common reason a car will fail is due to a check engine light(should be called an emmissions light). The test can not be run if the check engine light is on. Even if the codes in the computer are reset, to temporarily shut off the light, it will not pass. There are readiness codes that are stored in the cars computer, and resetting the light resets those. Also, even if you are emmissions exempt, your car still MUST undergo the normal safety inspection, and there is actually still a partial emissions test(basically just hooking it up to the pc to make sure everything is operational). That is why there is a charge for the emissions exemption, otherwise it would just be the cost of the sticker. Ok, sorry if i rambled, just thought i would share my knowledge on the subject.
Posts: 2,838 |
It all depends on the area you're in as to what gets done . Pre-96 cars in MY area just get a visual inspection of certain components to make sure they're present & accounted for & they test your gas cap . They still "F" you for the emmisions inspection cost , not just the $2 for the sticker , however .
~~~~~~~ Phil
Black & Tan 2000 SVT Contour #2137 of 2150
35,000 miles & counting !
