Page 2 of 2 1 2
#842195 01/14/04 12:36 PM
O
O
brianl703 I,am with you!Looking at the futura to replace
the contour in 2006.
New Pics of OUTKAST 1!Sept2006
#842196 01/14/04 01:24 PM
V
V
My attitude is you will never get any money for your Contour, so you better be damn sure you want a new car with not much better performance before you trade in your 'Tour.
E0 #36 '95 Ranger '82 Honda CX500
#842197 01/14/04 05:59 PM
V
V
Edit: Didn't mean you or your car personally, just meant all of us with Contours. Didn't intend to sound harsh
#842198 01/14/04 11:29 PM
I would do what Andy suggested. You will be so happy you have another car to bum around in, and you will find your new car a pleasure to drive everytime you get behind the wheel.
Birthdate 1/6/2000 Mods: 35% Tint Bosal Exhaust K & N Air Intake, MAF Koni & Eibach Spec I/Spec Flywheel DMD http://www.villagephotos.com/pubbrowse.asp?selected=895138
#842199 01/15/04 03:31 AM
Originally posted by brianl703:
My '96 is at Sheehy Ford right now getting the 99M03 recall done (well it will be when the replacement harness kit gets in).
I think I'm going to drive that '96 around for a couple more years, then I'll replace it with an '06 Futura (my sister works at a Ford dealer so I can get the D-plan on it, which should save a few thousand).
I won't trade the '96 in, that's a good way to get screwed by the dealer, especially when buying a car under D-plan. Plus my mom wants it to replace her '97 Escort. Nothing wrong with the '97 Escort, the Contour is just a nicer car, even if it's a year older.
Did you have specific problems crop up before getting the wiring recall done, or did they do it just because it was "under recall"? I've got a '95 that's probably less than six months away from breaking the 100K mark and I'm pretty sure it's not been done, but I haven't seen any insulation problems.
#842200 01/15/04 05:43 PM
First I noticed a crack on a wire going to the IMRC box (your '95 doesn't have one, it's different than the '96 models). A couple of months went by and I checked again, and I noticed MORE CRACKS on that wire.
I went to Battlefield Ford (motto: Where Getting Warranty Work Done is a Battle) and they patched up the wire with some heatshrink tubing. I asked why they did that instead of replacing the harness under 99M03, and they said it wasn't covered, which I knew was BS. Their reasoning was that it wasn't cracking in an area that the 99M03 documentation directs them to inspect. I called 800-392-FORD, I taked to Battlefield Ford's customer service manager, they made it clear that they wouldn't do it.
A couple of days later I decided to do my OWN inspection, and:
I noticed one VERY TINY CRACK on wire on the engine cooling fan harness. The insulation on that wire (AND SEVERAL OTHERS NEXT TO IT) broke and fell off when I moved the wires around to get a better look. It appeared that with enough movement, I could easily have several inches of BARE WIRES on my cooling fan harness!! What happens if they touch? I didn't want to think about it!
Then there's the very-likely damaged wire under the intake manifold. (I had a '95 Contour, at 125,000 miles I did the intake manifold gasket replacement and almost every wire under the intake manifold had brittle, cracking insulation. I shelled out $600 for the harness kit and replaced that harness, the other 3 have yet to be replaced--it's now my brother's car and I think he's got plans to drop a 3-liter into it, at which time the other 3 harnesses can be more easily replaced).
That's when I decided to search for a better Ford dealer (I have had issues with Battlefield Ford in the past) and came up with Sheehy Ford, who agreed to perform the 99M03 service.
If you don't get this service done and your wires are cracking (chances are very high that you do have some deteriorated wiring in your '95, especially if you sit in ANY stop and go traffic in the summer--and that's the only kind of traffic we have here, right?), at the very least, you can expect corrosion of the wires and all sorts of electrical problems if any winter road salt water gets in them through the damaged insulation. At worst, you could have a fire.
If you check the wires on your own: Affected wires will look fine until you move them, then you'll see cracks appear and possibly the insulation will start falling off.
The most likely place to find this damage is under the intake manifold, but the cooling fan harness, where it's mounted to the fan shroud, seems like another likely place.
Page 2 of 2 1 2
Moderated by  Andy W._dup1, GTO Pete
