Posts: 1,746 |
Its very bad with mine, but my tires are about shot. Motor mount inserts are about the best cheap fix, although you will still notice it.
Posts: 6,106 |
Quaife, sticky(er) tires, poly motor mounts, suspension... These are all good things to have... I have them all and am putting down only 191HP and 190TQ at the wheels, and I have the same problem in 1st gear at a roll... But do the things people have been saying and you'll definitely feel a difference... After that, learning how to control it is all you can do...
Mark
2000 Black CSVT
Posts: 9,602 |
Torsen LSD (not Quaife)
Better/Taller tires (225/50 KDW or P03, 17's?)
Poly or 94A Roll Resistors
I have that problem any time above 1/2 throttle in 1st and 3/4 throttle in 2nd. Just lights up both tires. (though mine pulls straight as an arrow  )
In 3rd there is only a brief hint of wheel spin and only if I intentionally try by punching it from cruise to full throttle above 4500rpm or hard shifting into 3rd which I actually do try to avoid.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 98 |
17" rims, Quaife and zetec final drive gear for tranny.
98 E0 SVT Contour
Black'n'blue
Corbeau TRS seats/Roush prep'd MTX/Fidenza/Spec Stg II/KKM
I am Canuckian
I am Canuckian
Posts: 4,168 |
Well I am not running an SVT. But I am having the same problems with traction now especially since I put the SVT UIM on the car. I think alot has to do with the tires that are on the car right now.
Green 96 mystique gs 4cyl mtx
16.9 in the 1/4 mile @102500 miles
95SE in Midnight Red MTX
MSDS headers and y-pipe
SVT exhaust
SVT UIM
Optimized se TB.
Full pre 98 SVT body kit
15.741 @ 87.73mph :)
Posts: 6,106 |
Originally posted by DemonSVT: Torsen LSD (not Quaife)
And why is that? What warranty comes with the Torsen anyway?
Mark
2000 Black CSVT
Posts: 311 |
I run the Falken Azenis Sports... check those out... great all around tire... minus winter of course. But, they really bite! Those coupled w/ Bilsteins, intrax, and poly mounts... makes sure I can put most of the power down. Any of those things will help.
99 T-Red SVT
***Intrax, Bilsteins, Azenis, Offroad Y, CAI, Tint, Magnaflow Exhaust, Custom Grilles, Poly Mounts, Silverstar Bulbs, 100W Ion Fogs, Focus SVT Wheels, SHO UDP, Ford Racing Wires ***
Posts: 9,602 |
Originally posted by Y2KSVT: Originally posted by DemonSVT: Torsen LSD (not Quaife)
And why is that?
Performance. Plain & simple.
The Quaife is notorious for hunting back and forth under countless situations. (one being having more power than stock!)
That is not conductive to putting the power to the ground and tracking in a straight line. Both of which are needed to have a fast, predictable, & good handling car.
'nuff said.
2000 SVT #674
Posts: 300 |
Boy! I would like to have problems like that
SVT 99 #526 of 2760
Posts: 6,106 |
Originally posted by DemonSVT: Originally posted by Y2KSVT: Originally posted by DemonSVT: Torsen LSD (not Quaife)
And why is that?
Ahhh, I must not have one of the notorious Quaifes then... Mine seems to be doing the job...
I'll ask again, what warranty does the Torsen come with? How much do the Torsens run?
Mark
2000 Black CSVT
