Posts: 2,382 |
Well if it's the orginal key that won't turn then the inside of the lock must be messed up. A tumbler isn't moving like it's supposed to.
I think the dealer can prepare a new lock for you without too much hassle. The lock removes from the car from the inside. There is a cable attached to it going to the latch.
"Fear is the little death."
Muadib.
Posts: 1,505 |
try making a new key copy your key could be worn out just a sujestion
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
Posts: 2,382 |
a copy of a worn out key will be a new worn out key won't it?
Muadib.
Posts: 2,166 |
I have this problem occasionally.
Try a few different things.
1.) Try wiggling the key up and down while turning it.
2.) Try flipping the key over, and see if that works.
3.) Consider lock deicer. Additionally, you may have something jammed in the lock (salt)
Good Luck
- Zack
WANTED: T-Red HEATED Side Mirrors
FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps
2000 T-Red SVT
1995 LX V6 MTX (RIP)
Posts: 71 |
Originally posted by JACK: All of a sudden the key will not open the trunk I sprayed WD-40 and later tried graphite no luck any ideas?
I have 1995 Mondy, and I had a same porblem, my master key (with remote) couldn't open the trunk, but regular PATS key could so I figured it was the key that was the problem, it simply had weared out. So instead taking the PATS key with me (you don't want to loose that) I just had new, plain, key cut and it works.
airman1
Black '95 Mondeo
V6Si
