#840970 01/12/04 05:30 PM
Is it true that disconnecting the battery will clear all codes? If yes, how long to disconnect? I have to get my car inspected this month.
I am a troll.......... 2004 C5 Corvette Coupe, Mag Red/Light Oak, Auto Polished Wheels, Titanium Exhaust 2002 Chevy Malibu V6, remote start
#840971 01/12/04 05:33 PM
E
E
I play it safe and remove it overnight and it works like a charm. It should only take 20 or 30 minutes though...
Autozone will also clear them for free.
You can also remove the fuses for the PCM if you want.
1998.5 E1 SVT Contour #5482/6535
#840972 01/12/04 05:41 PM
I thought that they could only pull the code, but couldn't clear the CEL? At least they couldn't the last time we had a CEL.
#840973 01/12/04 05:46 PM
E
E
They have always cleared them for me. All I do is ask "Will you clear that for me to see if it comes back?" Then then say "Sure" Light goes out and then I go out for a six pack and wait for the light to come back on.
#840974 01/12/04 05:54 PM
F
Smurfette
Smurfette
F
lol doesn't surprise me Ed
Does NH check for CEL's during inspection??
#840975 01/12/04 05:58 PM
E
E
just discconnecting the battery doesnt always clear the codes
i failed inspection because of my 420 code, it was still in the memory, and that was after i had the cats replaced and had changed the battery.
#840976 01/12/04 05:59 PM
E
E
They just started up this year I believe. The guy at Martel showed me the inspection checklist and it was for the 2004 stickers and checking for a CEL was on there..
#840977 01/12/04 06:00 PM
E
E
Yes, I forgot. Pending codes need to be cleared using a computer or scanner. So Dick should have Autozone clear the code for him.
#840978 01/12/04 07:16 PM
i'm not sure if NH is the same, but in MA, even clearing codes may not save you.
If you disconnect the battery, the codes will dissappear (and depending on what kind of code, it may or may not be stored in memory). However, lets say that doing that clears all codes and your code was for an emissions issue, just clearing the codes and showing up at the station won't work exactly.
Reason being, all of your monitors will be set to 'NO', which means all of the monitors have not had enough data to determine whether or not the CEL should be on. Depending on what monitor (4 or 5 different ones), they stay at 'NO' until it defined drive cycle is met. The EGR monitor might need 5 drive cycles including the coolant temp. changing by 40 degrees F.....
If the inspection guy sees the monitors not having enough data being stored, you will NOT fail the inspection, however, you will also NOT pass it. They will do the traditional sniffer test if that is met....Then the results of that test will determine whether you pass or not.
Just be sure, once you've cleared the codes, drive around town for a day or so if you have a legit emissions issue...
If you have a dumb code that you're confident the sniffer test won't catch, then reset, then go.
I'm not sure if that explains it enough....
You can search the MA website - MA Emissions Website
Hugo ------ 98 SVT - 53k mi - SOLD 04 Mazda3 S 5-Dr
#840979 01/12/04 07:29 PM
As far as I know, NH does still not test emissions. According to what I've seen on Fox News ( ) in the past, Massachusetts has no business testing emissions these days either.
Doug 2006 Mercury Milan V6 Premier Dark Blue Pearl Former owner of a 2000 SVT Contour
Moderated by  baco99, frenchblueC2_dup1
