Page 2 of 2 1 2
W
whiteSE Offline OP
W
OK, I am about to order the Lambda Acoustic PB-10 4 ohms...is it worth to go 12" for an extra 10 bucks?
He's chaaarging!!!...(add scottish accent)...
In short, if you can spare the extra 1/2 cu ft, yes.
W
whiteSE Offline OP
W
Cool...I think I am set,,,My system will be:
HU: JVC LD-X300 Kamaleon
planet audio HTV-752 tubed amps (2)
Kenwood KAC 602 200 watts for the Sub
PLanet Audio PCKx 4" component speakers (45-20Khz), soft dome tweeter.
and Finally the LAMBDA ACOUSTICS PB-12..just placed the order...
Finally I think its a well integrated system
Sounds like a great system! Tell us how it sounds when you are done!
I'm a solid state man in the home and car but tube amps for the car sound very cool. I think that kind of sound would work very well in the hostile audio environemnt of the Contour.
i have some Pioneer separates for sale in the classifieds that may meet your needs... 55-25Khz... not as low as you're looking at, my reserve is set @ $70, so you may get a good deal!
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
My Alpine components can do 30Hz but it is not the same as a subwoofer. A 6.5" speaker can only displace so much air. Even with proper sealing the speaker con't compare to a sub for bass purposes, and you can muddy up the rest of the music without enough power. My deck is 60x4 and when I was using the components for bass (before I got the Lambda) it sounded horrible. Even hooked up to my Amp it still sounded wrong.
Page 2 of 2 1 2
Moderated by  dnewma04_dup1
