Page 2 of 3 1 2 3
Well, the computer is what causes the EGR valve to open, not the DPFE.
In any event, get rid of the 327 first.
Steve
why not just take the EGR valve off and then clean it out with carb. cleaner and put a vacuum on it to make sure the vacuum section controls the valve.... then you can blow into one end to see if the valve really closes or stays open when you want it to... and there are test you can do on a DPFE or any sensor for that matter with a plain old multimeter/volt ohm meter.. i downloaded a operating manual from the web site for Sunpro by actron III digital multimeter, but the instructions can be used with just about any multimeter.... go to
www.actron.com and look up manual on the left side of the screen for actron products, multimeter... its about 36 pages long i PDF format.. you need acrobat reader to view it.. hope this helps... i need to check out the DPFE on my 93 taurus, getting the bad codes for that also... but it should work on any dpfe sensor...
Not true. I operated mine with just my personal facial vac - no problem.
You have the basic proceedure right. If you apply vac, the engine will run rough(er) & possibly stall. That is IF you have an EGR that is operating properly. You should also be able to crimp the hose while the vac is applied & hold the rough(er) idle. This will tell you if the EGR has a leak in the diaphram.
If you EGR passes these tests, then you replace the DPFE. The original is an aluminum box about the size of a Zippo lighter on the block, just below the EGR valve. The newer ones will have a black plastic housing. Each will have an electrical connector, two hoses, and two bolts holding it on the block. A simple repair made tricky because of tight access.
It is my theory that the new DPFE housings are made from recycled water pump impellers.
PLEASE NOTE:
When you replace the DPFE, you will want to perform a TB cleaning. A simple & cheap proceedure - Your wrenches, one small screwdriver, $4 gasket, $3 for TB cleaner (do not use carb cleaner). You MUST be CERTAIN to clean the EGR channels behind the TB gasket (probably stuck to the Upper Intake Manifold).
These clogged channels may be part of what caused the DPFE to fail.
IN FACT, YOU MAY WISH TO CLEAN THE TB PROPERLY FIRST. This may restore EGR flow & raise the DPFE voltage & rid you of your problem - without replacing anything.
Hehe, then you may have another career opportunty in personal services..
J/K
I prefer using a hand operated pump with gauge. I can control the vacuum and check for leaking diaphragms too.
My name is Richard. I was a Contouraholic. NOW: '02 Mazda B3000 Dual Sport, Black BEFORE: '99 Contour SE Sport Duratec ATX Spruce Green PIAA 510's, Foglight MOD, K&N Drop-in
Hehe, then you may have another career opportunty in personal services.. Ouch!!! You'll pay for that!...Um, I mean I'm gonna get your @ss!!...No, wait...I'm gonna beat you!!...No, no good...Crap, forget it.
I grew up a poor farm boy in Northern Maine. Vac pumps were unheard of. Besides, I couldn't justify buying a gauge if I could just buy a length of vac hose for $1 and also have spare tubing whenever I might need it. Ain't I the industrious Boy Scout.
I didn't have one till fairly recently. I have the little Mighty-Vac (Metal One) with the brake bleeding accessories. My wife could never get the hang of pump, hold, release (Not what your thinking, I am talking about brake bleeding). If I get frustrated enough explaining the problem, she says to buy the tool that makes it easier and then I won't need to yell so much!
It's easirt to bleed brakes with the vac pump then using "facial vacuum" to do it.
BTW, I think you coined a new term. I have never heard it called Facial Vacuum before. Funk and Wagnalls may be calling you this minute...
I'd never put a vacuum on my brake system. I use a simple one way check valve thingy from the auto parts store. One man brake bleeding kit.
yes, thats why i bought the mighty vac also at autozone for about $25, the plastic one, but it works good...
i never could relay how to pump the brakes when under the car and just about gave up..until the mighty vac..
you might also be insterested in the :
Speed bleeders: http://www.speedbleeder.com/
I seem to be having the same problem on my 95 mystque V6.Where is the d.p.f.e. located? All I can see is a senser located on the rear of the u.i.m. two vac. lines,one from the e.g.r. and elec. conection,this senser is a round barrel like object.Does the d.p.f.e. go buy any other name because I have not found a listing for it in any parts books
thanks
thanks
The round, barrel shaped piece you described is the EVR solenoid.
The DPFE sensor is below that on the firewall side, buried way the heck under everything else. Look down from the IAC valve.
The DPFE often goes by names that include the following keywords: EGR, Pressure, Sensor . For example, AutoZone's site calls it the "EGR Valve Pressure Sensor" - $53.99 for a Wells SU282 for a 98 2.5
Steve
Page 2 of 3 1 2 3
