Page 2 of 3 1 2 3
#836376 01/08/04 07:24 AM
Just thought I would add that the amp you picked out from ebay is a 2-channel amp so you will not be able to "push all 4 speakers" Nice amp from what I have read though.
98' Contour SVT #607 of 6535 05' Mazda 6s Audio/Visual enthusiast because it's one of the many things I went through 4 years of hell for
#836377 01/08/04 02:34 PM
You can use it to run all four speakers, but you'll lose front/back fader control.
1999 Ford Contour SVT #900/2760 (SOLD) 2005 Mazda 6s 2003.5 Mazdaspeed Protege 1998 Ford Ranger 4x4
#836378 01/08/04 03:22 PM
V
V
Surprised you guys aren't recommending upgrading the rear speakers. I did my fronts first, then the rears about 2 weeks later. Made a huge difference.
E0 #36 '95 Ranger '82 Honda CX500
#836379 01/08/04 03:51 PM
Do all 2-ch amps support 4-ch if you don't find losing front/back fading control?
#836380 01/08/04 04:24 PM
Provided they're stable in 2ohm stereo. Most are.
#836381 01/08/04 06:34 PM
Chomp,
Could i use that amp to push the first set of Crystals (the ones for $45) or would it be too much power.
If too much power what if I send it across to the fronts and rears, instead of just fronts.
Thanks,
Joe
1999 Contour SVT ~ Black w/Tan Current Mods: Fog light rewire, 20% Tint, SVT Banner,Rockford Fosgate RFX-8340, 2-12" Bostwick SPL Subs & Audiobahn 600x2 Future Mods: Knauberizing it, lowering
#836382 01/08/04 08:09 PM
Originally posted by SVTJoe:
Chomp,
Thanks,
Joe
You could. You'd just need to turn the gains down (effectively makes it a less powerful amplifier).
Using it to power the fronts and rears, it would send 100w to all four speakers when using parallel wiring. Again, you'd have to turn down the gains.
#836383 01/09/04 01:53 AM
Do most car audio amplifiers have a gain adjustment? In fact, you are not really lowering the gain directly but rather raising the value of the resistor that is connected to the base emitter of transistor which in turn lowers the gain
#836384 01/09/04 04:13 AM
I haven't seen one without a gain adjustment, but there's always some exception out there.
#836385 01/09/04 04:22 AM
If there is one without a gain adjustment, it's easy enough to rig up a couple of potentiometers to be your gain adjustment. Audio input to middle terminal, one outside terminal to amp input, other outside terminal to shield/ground of head unit output/amp input.
Dunno what size (1K, 10K, 100K?) of potentiometers you'd want to use but they're cheap, so experimentation won't cost much...
Page 2 of 3 1 2 3
Moderated by  dnewma04_dup1
