Posts: 2,426 |
Originally posted by Jason43: Yes the Borla is an excellent sounding and performing exhaust. The quality and fit is top notch as well.
Absolutely. I got mine from the GB and it sounds great, looks great, and went on with no trouble. The butt dyno tells me it helps with the power, too.
Posts: 3,627 |
Originally posted by hetfield: Originally posted by KingpinSVT: yes it is a good exhaust, pretty expensive though. you are better off IMO going with trubendz, located here: http://www.trubendz.com/home.asp
you can get the borla pieces, for a few hundred bucks less. you may notice a small gain, with the keyword being small. the gain will be better paired with a good intake.
Someone local to me, Thinkmoto, has the Trubendz. While we both really liked the tone, the volume was a little on the quiet side. That's the only aftermarket exhaust I've personally been able to listen to. I'd love to hear the Borla, Bassani, and Brullen in person. Most of the sound clips I've heard are recorded on cheap equipment so its difficult to compare.
I have the trubenz borla and like the first three months were quiet but now its just damn deep and sounds great just make sure you get the resonated exhaust.
Trollin the boards as of 9/23
Originally posted by GS474: stock hp is never enough
Posts: 71 |
I was reading some where and it was posted that the Borla exhaust actually is worse for HP then the CSVT exhaust. Is that in anyway true?
'98 SVT E0 Silver
-TRENDWHORE!
Selling out never felt so good!
Posts: 10,015 |
No way the stock muffler on the SVT are all absolute junk. The piping (aft of the y-pipe) on the other hand is relatively good, and as such simply swapping out the stock parts for a Magnaflow resonator and Magnaflow mufflers out back is a cost effective way to improve both performance and sound. If you need Magnaflow parts, PM me.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,881 |
Originally posted by Big Poppa: I have the trubenz borla and like the first three months were quiet but now its just damn deep and sounds great just make sure you get the resonated exhaust.
Why does the Stainless steel system only have one muffler and where does it go in the system? Is it before the split? I'm on the waiting list for the Borla GB and they are both the saem price.
1998 T-Red SVT #957
Born 5/14/1997
Posts: 1,616 |
Originally posted by TommySVT: Originally posted by Big Poppa: I have the trubenz borla and like the first three months were quiet but now its just damn deep and sounds great just make sure you get the resonated exhaust.
Truebendz has the muffler in the "stock" systems resonator position...right before it goes around the gas tank.
Posts: 1,508 |
Originally posted by Mark_West: I was reading some where and it was posted that the Borla exhaust actually is worse for HP then the CSVT exhaust. Is that in anyway true?
It has been dyno proven that the Borla gives better gains for low end torque (under 4K RPM) and low end HP. Up high in the meat of the band, brands like Bassani and Brullen give better gains. For example, I gained 15 HP at the wheels with an intake and Brullen system at 7K RPM and lost HP and TQ at 3000 RPM. Another SVT with a Borla gained 7 lbs of Torque and 5 HP at the wheels around 3500 RPMS and 4 HP and 3 TQ at 6800 RPM.
1998.5 E1 SVT Contour #5482/6535
Posts: 1,746 |
No, that is not true in any way.
Posts: 853 |
IIRC the Borla System for an svt cost around 700ish shipped. (Borla's web page didn't work for me)... just seeing what others actually paid for theirs?
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998
WR Headers GMK CAI
Blaupunkt system fiberglass tweeter pods
L.E.D. tail lights in the works
Posts: 294 |
$290....used....and bent on one side
'04 Cobra Convertable!!
