#83557 12/05/01 04:27 AM
600 watts mono @ 4 ohms - what to do, so many choices!
My two ideas were one 12" Dayton DVC in a ported box or one 12" Blue print in a ported box.
One other idea I had was to build a isobaric box for the 2 IDQ 12's I have.
I don't care what kind, or how many drivers I use. I don't care what kind of box - I just need a really small enclosure 2 cuft max that will be high SPL/SQ.
#83558 12/05/01 04:31 AM
I
I
Trust me all you would need is 1 kicker solo square in a sealed box with a good amp and it will pound better than the others you suggested.
Jerry
97 Contour Sport V6. T-Red, KKM tru rev induction, Ford racing wires, Cooper Cobras GTH, A pillar gauge pods with ford racing gauges, Clifford Matrix alarm, painted red calipers, full bra, premium audio installed,LED's, Ford Racing seat belt pads. It's my baby!!! I love to pull up to a honda or a VW and blow their "fast and furious" doors off. Imports can suck my american exhaust!!!
#83559 12/05/01 04:42 AM
Not a bad woofer for $100.00, Dual two ohm coils (so you can acheive 4 ohm mono and allow it to get 600 watts)
T/S Parameters (coil in Series):
Fs: 35.36 Hz
Qms: 5.6875
Vas:37.475 Liters
Cms: 135 um/N
Mms: 150 g
Rms:12.92 lb/s
Xmax: 17 mm
Sd: 442 sq. cm
Vd: 0.751 liters
Qes: 0.828
Re: 3.0625 ohms
Le: 2.6875 mH
Z: 4
BL: 11.1 Tm
Qts: 0.723
1-W spl 85.05
2.8-V spl 89.22
Power Handling is 500 watts rms per coil,
#83560 12/05/01 12:38 PM
APT Offline
For $99 the 12" DVC is tough to beat. Knu's is very good as well, but the Fs is a little higher than what I like (my 8" has a lower Fs, Bill!). The Dayton is a little more efficient than Bill's driver. The Blueprint 1203 is nice too, but I don't think worth twice as much as a a Dayton.
Why did you want a ported enclosure? Unless you are competeing where you want the extra 3-4dB or you are working with underspec'd driver, I recommend a sealed box. They are smaller, cheaper, and easier to build.
You isobaric design sounds interesting as well. I think the only advantage to that design is that you cut the size of the enclosure down in half.
As for the Kicker, it would be enough, but I believe Dave ran the simulations on it and compared to a Shiva and some other lesser known drivers. It was unimpressive considering the price.
#83561 12/05/01 12:52 PM
Jerry
:rolleyes: :rolleyes:
That is the best response I could come up with. Do tell, why the solobaric will "pound" better?
#83562 12/05/01 12:53 PM
Bill's woofer is a good choice, but needs to go in a ported enclosure for the best sound. Since it doesn't matter what kind of box, that doesn't really matter.
Is this for home or car?
#83563 12/05/01 02:03 PM
Finally pulled the trigger and bought a second car - 1999 Saab convertible. While I love the SPL/SQ of my current setup, I realized I have to work in the confines of a small trunk. I also wonder how it will sound with the top down (will I loose much volume?).
A ported box seams like the best way to maximize effieciency. Do you guys think a single Dayton w/ 600 watts can match the output of two IDQ's sharing 400 watts?
#83564 12/05/01 02:31 PM
What sub is Knu showing? The baskest looks identical to the basket on my PL except mine is black. Is that a Lambda sub? confused
#83565 12/05/01 02:35 PM
Nope, but the basket is made by the same manufacturer. His sub is made by TC Sounds. I don't know who the basket supplier is though.
#83566 12/05/01 05:06 PM
Basket is russian made. This woofer does "pound" wink , in a ported enclosure though
Edit: I'll see if I can post a plot from Bass Box.
Moderated by  dnewma04_dup1
